Guest Anonymous Posted February 2, 2003 Report Posted February 2, 2003 I took the computer out of my new GP today and got the numbers off of it. Can you tell me if it has the 2.8 chip or 3.1 chip? Here's the numbers... BTW, the sticker on the computer says it's a reman. #'s on computer- SVC# 16198260 Barcode-110049107598021 #'s and letters on chip- APWK 2385 Quote
eclipse5302 Posted February 2, 2003 Report Posted February 2, 2003 I'm not Ben or Shawn, but APWK is for a 2.8. Jason Quote
Guest Anonymous Posted February 3, 2003 Report Posted February 3, 2003 I knew others would know and it wasn't meant to be limited to them. But anyway thank you for the reply. Now I know why my new GP runs like an azz! Guess I'll be going to the yards tomorrow. The guy that put the 3.1 in my GP before I bought it is actually a mechanic at a GM dealer. You would think he'd know enough to change the chip. :cuss: Quote
Guest Anonymous Posted February 3, 2003 Report Posted February 3, 2003 How much actual difference is there between the 2.8 and 3.1 chips? Would it be better to try and get the chip from the car the motor came out of or will any 3.1 chip do? What years will work? Quote
Vegeta Posted February 3, 2003 Report Posted February 3, 2003 what year is it? EGR type? Using ALL 3.1 stuff? Quote
Guest Anonymous Posted February 3, 2003 Report Posted February 3, 2003 It's an '89 GP. As far as I know everything is from a 3.1. The tranny is the original I believe. I'm not sure what the types of EGR are but it has no wires running to it. I'll try to get a pic of it. EDIT: Here's a pic... Quote
Vegeta Posted February 3, 2003 Report Posted February 3, 2003 ok, its a vacuum EGR. ARZW should be the chip that works for you. its an 89 3.1 W body 4 speed chip. Quote
Guest Anonymous Posted February 3, 2003 Report Posted February 3, 2003 Thank you very much. I'm going to try and get ahold of the guy that put the motor in and see if he can get the computer out of the car the motor came from. Quote
Guest Anonymous Posted February 3, 2003 Report Posted February 3, 2003 Will a '92 chip work? The guy at the j/y insists it is the same. Quote
SleeperRed90TGp Posted February 3, 2003 Report Posted February 3, 2003 Just an observation but that egr looks exactly like mine and I have several wires running to it. I can bearly make out the cavity for the plug but you can deffinatly see where the plug latches on top. That little rectangle sticking up at the top front of the picture is where my wiring plug clips over. I also have a vacume line in the same spot yours is. Here's a link that lists gm computers. http://www.cruzers.com/~ludis/p4xref.html#1227727 Quote
Vegeta Posted February 3, 2003 Report Posted February 3, 2003 Tell the guy in the junkyard to look at the EGR valves. They are not the same nor are the chip codes. A 2.8 chip meant for vacuum EGR should work fine though on a 3.1 with the same EGR. It might be slightly off but shouldn't run strange. It might be those wires if they arent connected to the EGR. Quote
Guest Anonymous Posted February 3, 2003 Report Posted February 3, 2003 Sleeper, you are correct. Mine DOES have wires running to it. It was getting dark the other night when I looked and I didn't notice them. So, what now? Quote
SleeperRed90TGp Posted February 3, 2003 Report Posted February 3, 2003 Looks like that mechinic never hooked up your egr! I would think the harness is hanging there behind the motor. As you know you can slave the motor to get a better look. Don't take the alternator off the harness is on the other side.I don't reconigize the computer part number. Sounds like maby its an aftermarket number. As far as I know we have a 1227727 computer as do most gm vehicles of this vintage with several memcal's. Mine is auad which is listed on the link I posted. I couldn't find yours. My car was built in late 89 or early 90. I rebuilt my motor a couple of months ago and forgot to hook up the egr plug. Like Ben said the only thing I noticed was it idled a little high. I thought it was the aftermarket cam but it was the egr. It idles fast anyhow due to the tg chip so I didn't think much of it accept I got tired at stoplights unless I put it in nutral. I discovered it when I wired the 7th injector. As far as a 92 memcal I am not sure but I doubt it. One, no turbo and so there for no boost control , two they had the 4t60e trans which the computer controls the tranny. Ours is controled more by the modulator for shift points at least. I don't think thats why your car is running bad. I dont think you will find a tgp chip in a junk yard. Sorry i can't be more help. There was a guy named mik or mike that used to post on either this site or the tgp site that could answer your questions. Haven't seen him in a while. He got into it with sombody and hasen't posted in a while. To bad. Is your car a gp or tgp? I assumed a tgp by your sign. If you need a memcal let me know. Quote
Guest Anonymous Posted February 3, 2003 Report Posted February 3, 2003 I do have a TGP but this is in my '89 GP that I just bought. Here is the computer from the link you listed. It was in the first set. It's the third computer. Chip is APWK 2385. I don't see this chip listed with these computers though. 1227727 16197128 16198260 Schematic More info Description: 1227730 in underhood case Application: 1990-92 2.5 L4 TBI “R†LR8 (“W†body) 1988-89 2.8 V6 PFI “W†LB6 (“W†body) 1989-93 3.1 V6 PFI “T†LH0 (“W†body) 1989-90 3.1 V6 PFI turbo “V†LG5 1990-91 5.7 V8 TPI “8†L98 (“Y†body) MEMCAL IDs: “Râ€Â: APTW, … “Wâ€Â: AMAS, APWM, ATRA, … “Tâ€Â: ARCX, ARZW, ATSN, ATSP, AUMY, … “Vâ€Â: ASAN, ASMF, ATMJ, ATMK, AUAD, AUAF, AUFR, AZRC “8â€Â: ANHT, ARFP, … EPROM type: 27C128 or 27C256 Actually the EGR is plugged in. Can you get me a prom for this? Quote
Vegeta Posted February 4, 2003 Report Posted February 4, 2003 there are a LOT of memcals for this computer. Quote
SleeperRed90TGp Posted February 4, 2003 Report Posted February 4, 2003 No all have is the tgp memcal. I am sure you can find your memcal at the j/y. Here is another link that i forgot about. Your chip is there. http://www.backstreetautomotive.com/superchipsOlds.htm Quote
Vegeta Posted February 4, 2003 Report Posted February 4, 2003 Better jump on that killer deal of a blowout price. Only 190 bucks for a chip that doesnt give you any performacne:) Quote
Guest Anonymous Posted May 24, 2003 Report Posted May 24, 2003 OK, I just got a computer with the ARZW chip. I put it in and the car was very hard to start. I did get it too idle, although very rough. When I tried giving it gas it cut off immediately. Is it possible the computer is bad and the chip is ok? Quote
Guest Anonymous Posted May 24, 2003 Report Posted May 24, 2003 Well, nevermind now. I took the ARZW chip and put it in the computer that was in the car. Runs fine now. Well, except for the bad bearing(s). Quote
