sicksense7 Posted June 24, 2005 Report Posted June 24, 2005 i just bought an 88 regal limited yesterday, and it needs the cv joints replaced......how do i tell if it has ABS or not??? I can't order parts until i know. thanks!! Quote
joberlee Posted June 24, 2005 Report Posted June 24, 2005 It doesn't.unless it's one of the preproduction 89s with abs. I know someone that had an 88 Gp with a factory installed HUD that said Hughes on it. Look at the master cylinder, if it says anything on the top of it other than what type of fluid to use then it could be a PM3 abs car. Quote
Lee Posted June 24, 2005 Report Posted June 24, 2005 This is a PMIII Oh!! :?: Are those crossbars on my Regal :?: A joke from a prievious post Quote
GnatGoSplat Posted June 24, 2005 Report Posted June 24, 2005 Actually, Regals were the "pilot" for PMIII ABS and it was available in '88 for Regal only. Cutlass and GP couldn't get it until 89. It's pretty rare, so you probably don't have it. Easiest way to tell is if your brake fluid cap is round, then you don't have it. If the brake fluid cap is large, flat, and trapezoid shaped, you do have it (and will wish you didn't). Quote
jeremy Posted June 24, 2005 Report Posted June 24, 2005 moving to the Brakes/Suspension/Steering/Wheels/Tires Section Quote
