cutlass1991 Posted June 23, 2005 Report Share Posted June 23, 2005 What would cause this to occur? Sometimes I'll have to try starting the car several times before the motor actually turns. Lately this problem has been getting worse, but it has been happening for over a year. Has this happened to anyone else? Quote Link to comment Share on other sites More sharing options...
GnatGoSplat Posted June 23, 2005 Report Share Posted June 23, 2005 Yeah, the 88 Cutlass my wife used to have would do that on occasion. I had to replace the starter. Quote Link to comment Share on other sites More sharing options...
jeremy Posted June 23, 2005 Report Share Posted June 23, 2005 sounds like the starter is on it's way out. Quote Link to comment Share on other sites More sharing options...
Regal_GS_1989 Posted June 23, 2005 Report Share Posted June 23, 2005 Does the starter actually turn, or just click?? IT could also be something as simple as a bad connection at the battery. Quote Link to comment Share on other sites More sharing options...
1990lumina Posted June 23, 2005 Report Share Posted June 23, 2005 Does the starter actually turn, or just click?? IT could also be something as simple as a bad connection at the battery. Check the aux. positive terminal on the strut tower as well Quote Link to comment Share on other sites More sharing options...
cutlass1991 Posted June 23, 2005 Author Report Share Posted June 23, 2005 The starter just clicks, then after a few trys, it will start the car. It seems like it is a bad electrical connection, but the starter was never touched or replaced so there shouldn't be anything loose on it. I do have a lot of crap on the aux positive terminal, a couple of power wires for amps.... That might have something to do with it. I think I'll check the wiring and go from there. I may just replace it, I don't think it will be that hard or expensive. I never did one before, but I'm sure I could get through it with the help of this site. Oh, and this forum is fuckin awesome. I can't believe I can get four responces within 10 minutes at 8:30 in the morning. You guys are really on top of things. Thanks, -Dan Quote Link to comment Share on other sites More sharing options...
jeremy Posted June 23, 2005 Report Share Posted June 23, 2005 I would try checking the Aux terminal first because it is obviously easier, but I still would bet it is the starter Quote Link to comment Share on other sites More sharing options...
Lee Posted June 23, 2005 Report Share Posted June 23, 2005 Mine did that for two years and it did it more if the wheels were turned. I had all kinds of theories for it but it ended up just the starter solenoid. When it worked the starter turned over fast and normal. It was recomended to me to change out both the starter and solenoid as it would be cheaper. Been good for three years now. Quote Link to comment Share on other sites More sharing options...
Tru2Chevy Posted June 23, 2005 Report Share Posted June 23, 2005 My car has been doing this for over a year. I went through 3 starts in about 9 months, and they all seem to do the same thing (each was replaced for free - lifetime warranty on them). Would just removing and cleaning the Aux. power terminal by the battery most likely fix it? I used to think the ignition switch was going bad, then I realized that everything else ignition related was working besides the starter. - Justin Quote Link to comment Share on other sites More sharing options...
GnatGoSplat Posted June 23, 2005 Report Share Posted June 23, 2005 It's always a good idea to clean the aux power terminal, and if you're still having problems, make sure the battery terminals are clean as well. Quote Link to comment Share on other sites More sharing options...
Tru2Chevy Posted June 23, 2005 Report Share Posted June 23, 2005 Cool, I'll give that a shot this weekend and see if it helps. I know the battery terminals are good, I just replaced it not long ago and cleaned them then. - Justin Quote Link to comment Share on other sites More sharing options...
THe_DeTAiL3R Posted June 23, 2005 Report Share Posted June 23, 2005 Does the starter actually turn, or just click?? IT could also be something as simple as a bad connection at the battery. Check the aux. positive terminal on the strut tower as well x2 I have to tighten mine up every now and then. Otherwise the car doesn't start it just clicks, and other weird problems also. Quote Link to comment Share on other sites More sharing options...
jimmy91444 Posted June 23, 2005 Report Share Posted June 23, 2005 mine was doing the same thing . After changing the starter it was still doing it. ended up being the wiring under the dash, some body installed some kind of alarm system and when they took it off they splice the big yellow wire(starter) with a smaller wire that di not supply enough power. Quote Link to comment Share on other sites More sharing options...
DiscoStudd Posted June 23, 2005 Report Share Posted June 23, 2005 One other thing to try: When the starter won't crank, put the car in Neutral and see if it'll start then. You could have a problem with the Park/Neutral safety switch if it starts when you put it in Neutral... Quote Link to comment Share on other sites More sharing options...
