Ok this is a completely retarded damn question... but is there a trick to getting the airbox open on the 3.4SFI in my 2003 monte??? Really bugging me i follow the instructions in the kit from k/n and that damn box will not open up far enough to get the filter in or out... Am i going to have to undo the throttle body or something to do this?
theres 3 little annoying clippy things, after u open it, lift towards u (drivers side) and it should pop out of them, then u can get to the air filter, my mom has a 3400 Grand am.
are K&N's car air filters good? I got one in my Honda 300EX ATV and it helps a lot, but that's a cone filter. Do their drop-ins provide any noticeable increases?
Apprently in my friend's 96 2.2 I4 cavy it does lol....but then again he's not the type of person to admit he got ripped off either lol....
He says it pulls a little better in the higher rpm, and in 4th gear when doing 90mph+ lol
Oh, they must be good then, because I know those 2.2 I4's are such high performance engines. To provide more power to them is nuts, how does he keep his tires from spinning with that new filter and all that new power??????? *end sarcasm* :lol: Maybe if I ever have extra cash laying around I'll take a gamble and put one in. Till then, my fram high mileage filter will do just fine.
Now just wait for anyone to tell oyu ur Fram air filter sucks lol :leaving:
lol, after the new clutch in his car it can chirp into second :shock: lol.
My friend's z24 actually has some balls. I was surprised. My friend Jake has the 2.2 I4 and my friend CB has a 2.4 DOHC. I drove both and they're both manual. There's a big diference. The 2.4 can easily bark em into 2nd and the 2.2 takes some real hamering to get it done. the 2.4 can keep a burn out from 1 - 3 while the 2.2 sort loses it in the shift from 1 -2. That could be motor or tires though. The 2.4's tires are practically bald while the 2.2's are pretty new. <-wow, what a worthless post, I just compared two crapaliers on a w-body site, sorry to swerve off topic.
wev used fram air and oil filters for years, whats wrong with them, lol
wonder if the guy ever got his air filter out! lol
fram oil filters are know to collapse and cause big problems
Jeff, is your friend's name by any chance Adam??? I know a Adam, with a 2.2 Cav, that thinks it's the shit, and he got a new clutch in too. LoL, would be funny if it was.
yeah getting the air filter box open on our 03 Venture was a bitch and a half!! We figured it out like what Prospeeder said above.
Fram sucks, if you're gonna go replacement filters and such, go GM ACDelco!!!
ok i will try this today, if i am reading this correctly i think i have been trying to open the airbox in the wrong direction, i didnt think the air box itself would move farenough to the fender to be accesible
:bash: dammit... maybe this wasnt a retarded question... me going frikkin nutz trying to get this thing open
:guns: ---> airbox :lol:
don't listen to what you were told above, the w-body box is different than the N-body box.
I found it easiest to replace that filter by unscrewing the air tube clamp at the throttle body, disconnect the 2 wire plugs (one on the MAF, one on the air intake temp sensor) pull off the breather tube, then pull the air tube back off the throttle body and lift UP. Then undo the 2 little clips on top of the box, and push the airbox lid (with attached tube/MAF) forward and lift up and out. There's 2 tabs on the bottom of the "lid" that hook in place. Install is reverse of removal, just be sure those bottom tabs go into place and you HOOK THE WIRES UP before you start the engine.
The other option is instead of unscrewing the tube clamp on the throttle body, just unscrew the clamp at the MAF sensor where it connects to the box, however if you don't have a good sense on how it goes back on, the MAF to box-coupling won't stay in place.
ok i thought of trying that... i was running out of patience with this go figure an air cleaner getting the best of me :lol: ... i used to have a neon ...
although after all of this i am thinking of getting the cold air kit i was gonna eventually get and putting that in now...
Crapaliers my ass!
2.4= 150hp 155tq
mid/high 15's, low 16's
2.2OVH- too slow
low 18's to high 17's
2.2DOHC ECOTEC- 140hp `150Tq
high 15's, low 16's
The little bastards are quick! just wait till you mod em! (Excluding the 2.2OHV) I know people N/A (No turbo or ntrous) And theyre running low 14's! :shock: And low 12's with boost. :shock: :shock:
The newer cavaloers are the only car i know that has less BHP than the monte STOCK that can frikkin kick my ass all over town... i stopped racing the fuckin things... tired of getting my ass handed to me by a little 4 banger... :roll:
