Supreme Cutlass Posted June 23, 2005 Report Posted June 23, 2005 I'm getting a digital instrument cluster from dsgrntld187, but he isn't including the senders to replace the switches. Where are they so I can yank them out of a boneyard car (pics pls if at all possible)? Quote
Psych0matt Posted June 23, 2005 Report Posted June 23, 2005 just stop at a parts store and pick them up, probably not worth the hassle to find something with working ones at a yard. I think most w's came with the switches anyways... Quote
Supreme Cutlass Posted June 23, 2005 Author Report Posted June 23, 2005 just stop at a parts store and pick them up, probably not worth the hassle to find something with working ones at a yard. I think most w's came with the switches anyways... I want SENDERS to REPLACE the SWITCHES and need to know WHERE THEY ARE on the car. Quote
Guest TurboSedan Posted June 23, 2005 Report Posted June 23, 2005 lol oil pressure switch/sender location is down under the coil packs, right in front of the starter. temp switch/sender location is on the corner of the rear cylinder head, on the driver's/firewall side - it should have a green wire coming off it. Quote
cutlsp Posted June 23, 2005 Report Posted June 23, 2005 there are 2 coolent switches one under the thermostat, one on the rear head. the oil pressure sensor is right by the oil filter with a 3 prong connector on it. Quote
Guest TurboSedan Posted June 23, 2005 Report Posted June 23, 2005 there are 2 coolent switches one under the thermostat you don't have to change that one. i think the one on the rear cylinder head is for the gauges and the one under the thermostat is for the ECM. Quote
cutlsp Posted June 23, 2005 Report Posted June 23, 2005 i found it the opposite josh i dunno one of us is right though Quote
Guest TurboSedan Posted June 23, 2005 Report Posted June 23, 2005 that's wierd. i'm almost positive i had to change the one on the cylinder head when i installed UB3 gauges. that was back in 2001 though. Quote
cutlsp Posted June 23, 2005 Report Posted June 23, 2005 only reason i meantioned the one under the thermostat is because i replaced both of them but the one under the thermostat is the one i had to replace so one of us is right josh. Quote
