Start isolating.. break out the spark checker, throw it between the wire and and coil first, move on to the wire and plug obiously if there's spark at the coil...
I know you know all this so you've probably tried it ;)
Listen carefully too.. hear arching anywhere?
Personally I don't think it's ignition. I'd checkfor 12v power at the injectors and see if they're getting grounded while the engine is running.
well when the engine is running on the front cyl's and you turn the car off the rear plugs are wet and smell like gas....
i think all the injectors are firing fine
Now you tell me!!!
lol
Crank sensor?
It's impossible for the rears to not be firing at all, because each coil fires a front and rear plug simultaneously. So all I can think of is maybe they're firing at the wrong time.
