Fuel Filter, why does my dealer want 190 bucks to change it
I live in edmonton canada and i have a 2003 montecarlo... i would like to change my fuel filter... dealer wants 190 bucks to do it, i looked into it and a filter for my car is under 20 bucks... where is it located and how do i change it myself.
All of that price is labor I think.
My fuel filter is underneath the car in front of the gas tank to the left in a circular housing. I've never changed it, but probably should.
I don't know if yours is in the same spot, but it very well could be
$190CND :shock: even in Canuckistani money, that's way too much! It's like a 10 minute job!
I don't know where they are on newer Ws but very likely they're in the same spot as the old ones like 1990lumina said.. should be in front of the fuel tank somewhere.
The dealer mentioned something about the passenger front inner fender having to be removed to do it???
Damn maybe they did move it.. I knew GM couldn't keep things easy for us forever.
It might be integrated into the fuel pump itself... let me check GM SI...
Edit: your dealer is trying to rip you off. SI lists about 9 steps, and that's counting removal of each bolt as a step. It's easy as pie, do it yourself...
I could swear that the filter is right in front of your gas tank, all it takes is taking off a couple of clips or maybe a set of wrenches.. 5/8ths and a 13/16ths wont take more than five minutes, just remember to release pressure on the lines by opening up the gas cap. damn dealerships...
I think the only ones the changed were the ones in the o5 trucks...
Hey where in Edmonton are you?
I can call my mechanic and ask him how much he would charge to do it..
Remember the dealers here work for around $90/hr
RUN AWAY. The dealer is trying to screw you out of your cash and not using any KY....
The filter is in the rear or undeneath the car. I don't have my manual at work or I would look it up.
Glock
It appears to be in the same place as any other filter. The only bolt you need to remove is the one holding it to the bottom of the car.
That dealer is trying to screw you for sure.
They want to charge you that much for the same reason they wanted to charge me 550$ to change the alternator on my car. And its the 3100 :?
North east
Dude, trust me, you don't need a mechanic to change it out.. I'm a manager at a lube shop and we change them all the time, all you need is a jack and maybe some wrenches5/8th&13/16thfor one side of the filter the other side should be held by a clip. by the way it should be changed out every 20,000 miles.
Just remember to relieve the fuel pressure before removing the old one. Other than that, it shouldn't be hard.
ok sounds kewl... now are we in agreement that it is still in front of the gas tank?
