truckfighter Posted June 21, 2005 Report Posted June 21, 2005 I thought I remember reading about being about to free up some power by adjusting the timing a few degrees... is it possible/advisable? What are the disadvantages? Quote
Aaron Posted June 22, 2005 Report Posted June 22, 2005 The best combination so far is a 6* retard of the exhaust cams with a 6* advance of the intake cams. More information can be found at http://www.60degreev6.com Quote
Kalgorn Posted June 22, 2005 Report Posted June 22, 2005 How safe is this though? I vaguely remember some people talking about it could possibly harm your engine. Is that true? Quote
Aaron Posted June 22, 2005 Report Posted June 22, 2005 It could I guess, but many people are running it with no harmful effects as of yet. Quote
soya_sauce Posted June 27, 2005 Report Posted June 27, 2005 where can i find the proper procedure to adjust the cam timing? is this mod only possible on the non-interference 3.4 L v6's ?? Quote
Aaron Posted June 27, 2005 Report Posted June 27, 2005 where can i find the proper procedure to adjust the cam timing? is this mod only possible on the non-interference 3.4 L v6's ?? Like I said above, http://www.60degreev6.com It is only possible on the 91-95 3.4s, which were the non-interference onces, but that is not the reason. Quote
joey b Posted June 29, 2005 Report Posted June 29, 2005 Um...on my 97 I've done the 6/6 timing. Quote
Aaron Posted June 29, 2005 Report Posted June 29, 2005 Let me rephrase, it has only been thoroughly tested and documented on the earlier versions, and the results on the later will be much different considering the cams are different. Quote
