Curlybandit Posted June 20, 2005 Report Posted June 20, 2005 Well, after I replaced the FOURTH part for this piece of shit GM disaster of an ABS system they call the Power “bastard†III, I thought my brake problems might be over, at least for a while. Sure enough, one more ABS problem has reared its nasty little head and bit me right in the ass.... again. :? Fist it was the Accumulator and the Accumulator switch. Then it was the right wheel speed sensor (which happens to be buried inside the hub and bearing assembly!!), and then it was the left side!! Now, I can hear the friggin’ accumulator pump cycling on and off more rapidly than normal, and it’s making this odd whining sound right at the end of its cycle. Both the ABS and brake lights are shining brightly on my dash, a constant reminder that my brake troubles are far from over. To make matters worse, this new problem of mine is causing the brake pedal to occasionally get hard and I lose friction with the rotors for about a second until they catch again. I just got the code pulled. It turns out it’s a 35: Accumulator pump running too long. WTF!! Hopefully this is just a relay or something. I’ve dumped WAY too much money into these brakes. Quote
Prospeeder Posted June 21, 2005 Report Posted June 21, 2005 ok, u people have offically made me scard of my cars braking system, so there absolutly no way to change it over to a newer ABS system contoled by the computer? Quote
19Cutlass94 Posted June 21, 2005 Report Posted June 21, 2005 Ive really never had a problem with my brakes, well except for during winter when the AUX positive wasnt tight enough and my brake lights were on and I had no ABS in the winter... oooo yes what a fun time that was but after I figured that out, been working perfect ever since. I know it seems like a dumb question but is your brake fluid full? I know mines starting to get low and I need to get more to fill it. Quote
Curlybandit Posted June 21, 2005 Author Report Posted June 21, 2005 I know it seems like a dumb question but is your brake fluid full? I know mines starting to get low and I need to get more to fill it. Yup. That was one of the first things I checked. Anyway, luckily I have a friend who is a GM tech who's gonna take a look at it this weekend. He's been my saviour more than a few times in the past. If and when I get this probem sorted out, I'll be sure to post up the outcome. Quote
GnatGoSplat Posted June 21, 2005 Report Posted June 21, 2005 ok, u people have offically made me scard of my cars braking system, so there absolutly no way to change it over to a newer ABS system contoled by the computer? You can't change it to ABS VI because the downpipe is in the way. You CAN change it to Bosch 5.3 or DBC-7 since those are fully self-contained. You'd just have to find a custom mounting spot for it and run custom brakelines to it. Those are better since they're faster 4-channel systems. Most people would probably rather just go to regular brakes than to plumb in one of those. Quote
Prospeeder Posted June 21, 2005 Report Posted June 21, 2005 hmm, iguess if i really wanted to keep this car as an investment, i would do that, cause i love the ABS, but other than that, no, i doubt i would do anything. isnt there a way u can repostition it or anything away from the downpipe? or is it completely impossible, might be somthing id look into if parts became to expensive or rare. Quote
GnatGoSplat Posted June 21, 2005 Report Posted June 21, 2005 For ABS VI, probably impossible. It's too big. You could possibly mount it remotely, but then you might as well get Bosch 5.3 or DBC-7 if you're going to that much trouble. Quote
digitaloutsider Posted June 24, 2005 Report Posted June 24, 2005 hmm, iguess if i really wanted to keep this car as an investment, i would do that, cause i love the ABS, but other than that, no, i doubt i would do anything. isnt there a way u can repostition it or anything away from the downpipe? or is it completely impossible, might be somthing id look into if parts became to expensive or rare. They already are too expensive, and I'd just say fuck PM3 and convert to the plain brakes, but I forgot how reliant you are on your ABS. Quote
Curlybandit Posted June 27, 2005 Author Report Posted June 27, 2005 I may have figured out what the problem is. I took the Regal to my mechanic, and he believes that it's the accumulator switch. This is actually not such a big problem because I just replaced it last November, so it should still be under warantee. Hopefully this will be the last of my ABS problems (ya right.... ) Quote
Curlybandit Posted July 14, 2005 Author Report Posted July 14, 2005 Ok. So now that I've picked up the Accumulator Pressure Switch, and brought the car over to a GM shop, they tell me that the Accumulator is garbage too.... WTF!! Thank GOD it's under warrantee. Quote
Prospeeder Posted July 14, 2005 Report Posted July 14, 2005 well its the accumulator that always goes bad anyway, there around 100-150$ i think, no to bad i guess, for service every 3-5 years or how ever long they last Quote
J Posted July 14, 2005 Report Posted July 14, 2005 I know mines starting to get low and I need to get more to fill it. that means your pads are wearing out, don't jsut fill up the resivior! Quote
Curlybandit Posted July 14, 2005 Author Report Posted July 14, 2005 well its the accumulator that always goes bad anyway, there around 100-150$ i think, no to bad i guess, for service every 3-5 years or how ever long they last Uhmmm... Not quite. The one I bought was through my friend who is a GM mechanic. I got his list price of ~$260.00 (CAD). GM's over the counter price is over $500 (CAD). I just replaced the thing in November 2004. Quote
Prospeeder Posted July 14, 2005 Report Posted July 14, 2005 really? that sucks, i was aware they were in that range Quote
