Theres an intersting sale going on at Harry's U Pull It in Allentown PA, if you pay $25 to get it every part you buy is $1 it could be an entire engine or gear box, its irelevant, and that leads me into what I need to know. The posibility of walking out of there with a getrag gearbox or garret t-25 and affiliated parts, for maybe like $35 is crazy. But out side of the obvious gearbox, clutch, pedals etc. what parts are different between manual and auto cars?
This would be an excellent sticky topic since this is a very desirable thing to do.
Guest TurboSedan
search. the info you want can be found in the first 3 pages of the Powertrain section....it's been covered many times.
have you tards ever tried using the search?
you search for "timing belt" you end up with crap about jesus
anyway for the 5 speed swap u will def need the following
shifter assembly
clutch pedal assembly
clutch set
flywheel
flywheel bolts
clutch slave
clutch master cylinder
pressure plate bolts
shifter cables
transmission
thats all i can think of atm
Guest Anonymous
:werd:
or search foor 5 speed, and u get
"it was like 5 am and we were speeding and this riced out crapalier...."
Guest TurboSedan
you don't have to use the search function; just look around a little before posting and you'll find the info you want. like i said, the info you want can easily be found within the 1st TWO pages of the Powertrain section:
http://www.w-body.com/forum/viewtopic.php?t=30354
http://www.w-body.com/forum/viewtopic.php?t=29613&start=0
http://www.w-body.com/forum/viewtopic.php?t=30021&start=0
i would have replied to this thread myself with the info requested, but repeating myself gets really old after awhile.
