91grandprixGT Posted June 17, 2005 Report Posted June 17, 2005 changed plugs yesterday, all I can say is that ac delco are crap, nothing but problems from the start, got the front ones out and in, no problem the rear comes along and nothing but problems arise, get all the plugs out fine, putting them back in and get it all back together, start the car, misses I figured didnt get one on right checked them all the plug broke inside the boot, take that plug out and went and got another one, when I did that I got new boots as well get the new boots get them all on (It was hot in the garage and I was tired and pissed) I was in a bit of a hurry put it all back together start up once, runs once started then died when at idle I'm like crap what now pulled the boots off (New ones might I add) and the boot broke inside and the piece that snaps onto the plug ripped out of the boot, pissed me off put old boots back on (got the one plug out) and didnt run again finaly found out that when in my rush to put the stuff back together I cracked the hose for the map sensor (damn 1mm thick pos) anyways fixed that runs like new again.... all I can say is that a easy 20min. task turned into a 4 hour hell for me oh, and might I add that at one point the block slid out from behind the tired and crushed my arm between the motor and firewall Quote
Donutboy97 Posted June 17, 2005 Report Posted June 17, 2005 man that sucks. if it took longer than an hour to do that, I would have walked away and had a beer. you have a lot of paintence or dedication to get it done. Quote
GP1138 Posted June 17, 2005 Report Posted June 17, 2005 You must have gotten old plugs or something. I've never had a problem with AC Delcos. Quote
1990lumina Posted June 17, 2005 Report Posted June 17, 2005 Never had prolems doing plugs yet...however I haven't done them in my Lumina yet...so I'll let you know lol.. Doing them on my RX-7 is so freakin easy...LOTS of room to work...I change them at every oil change (5000km) - 3500miles? And I've helped my dad do the plugs on his Taurus no problem. - Jeff L. Quote
cutlsp Posted June 17, 2005 Report Posted June 17, 2005 LOTS of run to work frueadman slip? the w-bodies are not that hard to do a tune up to i think you just screwed up on it :oops: Quote
1990lumina Posted June 17, 2005 Report Posted June 17, 2005 1990lumina wrote: LOTS of run to work frueadman slip? :oops: damnit not another one of my typos lol Quote
19Cutlass94 Posted June 18, 2005 Report Posted June 18, 2005 Doing them on my RX-7 is so freakin easy...LOTS of room to work...I change them at every oil change (5000km) - 3500miles? You change your plugs every 3,500miles?!?!?!?! Quote
Brian P Posted June 18, 2005 Report Posted June 18, 2005 WTF sounds like you had some user-problems there. Quote
91grandprixGT Posted June 18, 2005 Author Report Posted June 18, 2005 well being the first time I have changed plugs on a car like that, I'm use to v8's and v4's not any of that fwd v6 stuff.... oh well, and yes I screwed up a few times and I took consecutive brakes because I was getting pissed, just like the transmission, 4days total that sucked, about 6 hours a day while going to school, that was a pain Quote
GutlessSupreme Posted June 18, 2005 Report Posted June 18, 2005 well being the first time I have changed plugs on a car like that, I'm use to v8's and v4's not any of that fwd v6 stuff.... oh well, and yes I screwed up a few times and I took consecutive brakes because I was getting pissed, just like the transmission, 4days total that sucked, about 6 hours a day while going to school, that was a pain V4s huh? you sound well edjumacated on the subject Quote
1990lumina Posted June 18, 2005 Report Posted June 18, 2005 Doing them on my RX-7 is so freakin easy...LOTS of room to work...I change them at every oil change (5000km) - 3500miles? You change your plugs every 3,500miles?!?!?!?! Sure do...and the for 4 plugs costs $40 CDN because it uses those crazy plugs with 4 deallies..like the one in my avatar Quote
91grandprixGT Posted June 19, 2005 Author Report Posted June 19, 2005 well being the first time I have changed plugs on a car like that, I'm use to v8's and v4's not any of that fwd v6 stuff.... oh well, and yes I screwed up a few times and I took consecutive brakes because I was getting pissed, just like the transmission, 4days total that sucked, about 6 hours a day while going to school, that was a pain V4s huh? you sound well edjumacated on the subject you know, I just now realized what I said and I realize I made a total ass of myself.... I'm ashamed Quote
Brian P Posted June 19, 2005 Report Posted June 19, 2005 Doing them on my RX-7 is so freakin easy...LOTS of room to work...I change them at every oil change (5000km) - 3500miles? You change your plugs every 3,500miles?!?!?!?! Sure do...and the for 4 plugs costs $40 CDN because it uses those crazy plugs with 4 deallies..like the one in my avatar I'm just wondering if there's a reason you change them that much? Quote
cutlsp Posted June 19, 2005 Report Posted June 19, 2005 Doing them on my RX-7 is so freakin easy...LOTS of room to work...I change them at every oil change (5000km) - 3500miles? You change your plugs every 3,500miles?!?!?!?! Sure do...and the for 4 plugs costs $40 CDN because it uses those crazy plugs with 4 deallies..like the one in my avatar I'm just wondering if there's a reason you change them that much? prolly because the plugs wear out really fast since bosch makes them Quote
88Regal Limited Posted June 19, 2005 Report Posted June 19, 2005 oh, and might I add that at one point the block slid out from behind the tired and crushed my arm between the motor and firewall Ive had no probs with AC Delcos. Just don't go near borch platnum 4 plugs. The horror, the horror! Quote
1990lumina Posted June 19, 2005 Report Posted June 19, 2005 Doing them on my RX-7 is so freakin easy...LOTS of room to work...I change them at every oil change (5000km) - 3500miles? You change your plugs every 3,500miles?!?!?!?! Sure do...and the for 4 plugs costs $40 CDN because it uses those crazy plugs with 4 deallies..like the one in my avatar I'm just wondering if there's a reason you change them that much? prolly because the plugs wear out really fast since bosch makes them No, I buy NGK plugs...either way the rotary fouls them because it injects oil into the carbeutaor to lubricate the internal seals...and then burns the oil that is injected...plus there is alot more heat then a piston engine and that burns them up pretty quickly as well... If you don't change them often...you will get a nasty idle and very reduced performance. Anyway lol... Quote
19Cutlass94 Posted June 19, 2005 Report Posted June 19, 2005 yeah I was wondering why you changed them so often. That has to add up after a while of driving thought, I change mines probably every 45,000-50,000 miles, but I use AC Delco platnium plugs. But I dont know very much about those rotary engines, so that sounds like a pretty good explianation to me Quote
1990lumina Posted June 19, 2005 Report Posted June 19, 2005 It's actually very simple...three parts move inside the engine and that's it... But they aren't as reliable...and as you can see cost more to maintain. Quote
