89Cutlass Posted February 1, 2003 Report Posted February 1, 2003 Today i decided to take of the plenem to inspect the vacum lines under it and got it back on and now that motor starts and stalls right away. I think i might have to change the gaskets. Also were it splits at the air intake were the IAC is. Anyone had this happen or heard of it before. Thanks Quote
89Cutlass Posted February 1, 2003 Author Report Posted February 1, 2003 does anyone no what the gasket would be between the corner of the plenum and the air intake ?? Quote
89Cutlass Posted February 1, 2003 Author Report Posted February 1, 2003 I just went and bought a new intake gasket set. It came with the 2 upper the side gasket and the egr gasket for only 6.99. Ill change um tommorow i forgot that once you take them off you have to change them Quote
cmo1234 Posted February 1, 2003 Report Posted February 1, 2003 No frigging way 6.99? I got one set last week for like $28. damn. It did come with this extra gasket that was pretty big for the lower intake, but no way was I going to tackel that job. Just the top for now thank you. Quote
eclipse5302 Posted February 1, 2003 Report Posted February 1, 2003 Usually you can buy the set with or without the "valley pan gasket". This is the large lower intake gasket. Without the valley pan gasket is much cheaper than with it. Jason Quote
Brian P Posted February 1, 2003 Report Posted February 1, 2003 i need to do the valley gasket soon (again) has anyone successfully done this without getting coolant in the engine? I drained it last time and I still had a few drops get in... Quote
