01 lumina dash removal
does anyone know where i can get instructions to remove dash to put my deck in?
Basically all you have to do is remove the lower dash "kick panel" (4 screws,) tilt the wheel all the way down, apply the e-brake and shift into "LOW," and finally pull the upper dash trim out. It's a little tricky trying to finagle the left side out (where the little "pocket" under the headlight switch is) so make sure you have the driver's door open when you're removing the trim piece.
I found that it helps if you loosen the 2 steering column-to-dash bolts a little to drop the column down a couple of inches to give you a bit more room to wiggle the trim piece out.
