Sweet Jesus!
I found that the maxima that is local to me building the turbo kits gained 50hp on the same ammount of boost (7psi) by swapping turbos! He was running a T04E just like i have.... now he installed a 60-1 Standard which i a little bit bigger. he gained 50hp and it also spools quite a bit faster. ~2200 rpm faster or so. that is SICK AS HELL! so i might be upgrading my trubo once i build my kit
he is now pushing 420hp at the wheels on 7psi!!!
BTW its a 1997 Maxima SE 5spd
RedZ
compressor efficiency baby! :shock: :D . He should run more boost if he can, because 7psi on a turbo that big is ridiculous. I wish we could make 420 hp on 7psi. Wait, scratch that...I wish we could make 420 HP at all. I know it's possible, but I have never seen a 60* engine make that kind of power. I would think that the power curve must be very unstreatable with that size turbo. At what RPM does he have full boost??
I saw a Nissan 200SX SE-R with the SR20DET make 419 hp/412 tq at the wheels on a dyno at a Nissan meet that I went to with my friend, but that was with a lot of boost...25 psi :shock: :shock: :shock:
oddly enough his is EXTREMELY Streetable. he spools up at a very low rpm.. i will see if i can get a dyno plot.
RedZ
Maxima's are good sleeper cars to begin with....running a Turbo would be quite a suprise to many of the ricers out there!!!! 8)
hopefully i will see simmilar gains. i am running about a 1/2 a Liter on him so i should make more power. assuming his heads are not significanly better.
I guess i will have to see what i can do.. I feel the need to show him what a little Domestic tuning can do :)
altho his car is sweet. Looks bone stock with a low key tip!
RedZ
  • 3 weeks later...
curtis z-24 is making that kind of power. but of course its got a mixture of 3100/ls1/3.1L parts. I would be just satisfied with 300whp.
i am sure its due to the superior head design.
Heck yeah! 24v.. i am hoping i do simmilar power wise.. i might make about the same because i have more displacement but then break even with powertrain loss because i am an auto and he is a 5spd.
Shane
you could probably make wayy more power if you could swap the belt for a chain. I have seen quite a few 3.4's eat timing belts on the squeeze.
