cs-x Posted June 11, 2005 Report Posted June 11, 2005 I founf some mini gas shocks that some guy had in his car where the dogbones go. WTF are these? And should I put them in? I found them today on a cutlass international and pulled them.. $4.50/each so I thought what the hell. Quote
19Cutlass94 Posted June 12, 2005 Report Posted June 12, 2005 Why would you want a gas shock where the "dogbone" would be. WTF??? http://www.Fastfwdperformance.com Quote
cs-x Posted June 12, 2005 Author Report Posted June 12, 2005 That's what I'm asking.. I have a picture if someone can tell me how to post it Quote
Baddflash Posted June 12, 2005 Report Posted June 12, 2005 If you just drive like grandma then go for it , but they will allow more engine movement which is bad for performance. You have to host pics somewhere then link to them. Quote
19Cutlass94 Posted June 12, 2005 Report Posted June 12, 2005 engine movment = bad, youll wear the lower mounts out faster when your moves more than when it moves less, plus the lower mounts are a bitch to replace Quote
digitaloutsider Posted June 12, 2005 Report Posted June 12, 2005 Werd. Dogbones aren't exactly expensive.. Quote
cs-x Posted June 13, 2005 Author Report Posted June 13, 2005 OK, I'll host the pic on my shaw webspace.. but in the meantime, I think they're meant to work against the motor moving.. though that could be why the donor cutlass was in the jy since it had no collision damage. i'll post the pic tonight if i get a minute Quote
GnatGoSplat Posted June 13, 2005 Report Posted June 13, 2005 Are they those blue hydraulic damper things? I've seen them before. I think they're aftermarket. I don't remember who made them though. Quote
