Will a 00 GP GT CD Player work in my 94?
If it doesn't becuase it is to new, you can get on like that out of a Sunfire, and similar vehicles of the same era (94...) I say that because the newer decks need that special VIN thing..
someone more helpful hopefully will post.
you might have to modivy the mounting brakets but it oughta work fine
It's plug-n-play, and will bolt directly into the 94's dash. I had a stereo from a 99 GP in my 95 GP (same dash as your 94) and not only did it look stock, it worked perfectly.
1990Lumina The 00-up radios you're thinking about are the "Double-DIN" sized units that started appearing in Chevy's right around that time. Pontiac was slow to phase out their "DIN-and-a-half" radios (I believe the 03 GP was the last model to use that style radio.) All GM/Delco "DIN-and-a-half" radios did not communicate VIN info with the BCM.
Guest Anonymous
IIRC. they are exactly the same and should have the HUD info output.
