Sub enclosure that will fit in 92 regal???
Any body have a sub enclosure for 2 subs in there 92 buick regal 4-door or anything with a same size trunk? any year with the same trunk size 2 or 4 door. If so what are the dimensions? so i know what will fit. thx.
It really depends what size and make of subs you are using? I Have had several boxes in the trunk of my 4 door cutlass.
well there 2 12's and i know the length is a max of 36inchs i just dont know the max width and depth. the mounting depth of the subs is 6.5 inches!!!
Ok, Do you want a vented box or a sealed one? And it really matters which brand and model of subs they are because different subs work better in different boxes.
I have a couple different designs but I would need to know what exactlly you are looking for.
I know with my car the limit was 37" between the arms on the trunk lid. And the limit with the depth was 16" and the height was 14". And in order to get it into the trunk I would have to rotate the box with the subs facing the sky and pull the box out that way.
The box you see in my signature I specially designed for my car and it is 32" wide, 16" high and 14 deep. And its for a single 15.
