AWeb80 Posted June 4, 2005 Report Posted June 4, 2005 I know some of you use a vacume hose or line to suck it in the manifold...which one do you use and where is it at? TIA. Quote
GP1138 Posted June 4, 2005 Report Posted June 4, 2005 Take the brake booster vacuum line, the big one on the left, and suck it through that. Probably the easiest, IMO. I usually stick a funnel in there and pour it through the funnel. Quote
5speedz34 Posted June 4, 2005 Report Posted June 4, 2005 Yeah, it will suck it really quick, and usually enough to collapse the bottle. Quote
sl3196 Posted June 4, 2005 Report Posted June 4, 2005 Take the brake booster vacuum line, the big one on the left, and suck it through that. Probably the easiest, IMO. I usually stick a funnel in there and pour it through the funnel.Yup. Exactly the way I do it. I don't dump it in too fast though or it will kill the engine. Just keep the throttle open a bit and start pouring. Quote
GutlessSupreme Posted June 4, 2005 Report Posted June 4, 2005 If you use the brake booster line, squeeze it a bit so it's not wide open. It won't hardly do shit if it sucks it all in at once and there's a slight chance of hydrolock. You want to let it in slowly so it can do it's job. Quote
AWeb80 Posted June 4, 2005 Author Report Posted June 4, 2005 the big hose on the left?...of the intake manifold...ok, i'll look. Quote
AWeb80 Posted June 4, 2005 Author Report Posted June 4, 2005 i found the line, but geez, i can't get it off the booster......i got the clamp out of the way.....but the hose is still stuck on the booster. Quote
AWeb80 Posted June 4, 2005 Author Report Posted June 4, 2005 i feel it will pull the plastic part that the hose is connected to out of the booster Quote
slick Posted June 4, 2005 Report Posted June 4, 2005 Grab a pair of pliers, and grip right around the hose where it connects on the brake booster, and twist it around. It will brake loose. Quote
AWeb80 Posted June 4, 2005 Author Report Posted June 4, 2005 i got it....geez my car smoked...it was cool....now i'm waiting the 15 minutes before i go finish off the can... You guys that have used it, did u notice any difference in anything? Quote
AWeb80 Posted June 5, 2005 Author Report Posted June 5, 2005 wow that stuff is cool in smoked at idle when i was done for like 2 minutes... i then reved it up and blue smoke every where.....and it stunk. then i went down the road and full throttle to 65 mph and then drove about 70 mph for 2-3 miles and a small blue cloud followed me... Well, from this, i can feel a little more down-low power in OD....i doesn't kick out of OD up hills like it used to do.. It seems to rev easier through the gears.....all in all, i like it. Quote
glock19 Posted June 5, 2005 Report Posted June 5, 2005 keep yanking, it will come. Sorry to bring this tech post into the gutter..... Glock Quote
THe_DeTAiL3R Posted June 5, 2005 Report Posted June 5, 2005 Can someone please post a picture (with a circle or something) of the brake booster line that you are suppose to use (on a 3100 preferabley). I feel stupid asking this.. :| Quote
5speedz34 Posted June 5, 2005 Report Posted June 5, 2005 wow that stuff is cool in smoked at idle when i was done for like 2 minutes... i then reved it up and blue smoke every where.....and it stunk. then i went down the road and full throttle to 65 mph and then drove about 70 mph for 2-3 miles and a small blue cloud followed me... Well, from this, i can feel a little more down-low power in OD....i doesn't kick out of OD up hills like it used to do.. It seems to rev easier through the gears.....all in all, i like it. Did you shut it off after it sucked up the bottle? Or did you just go out and drive it? From my experience's it smokes more if you just drive and not let it shut off. Quote
sl3196 Posted June 5, 2005 Report Posted June 5, 2005 Can someone please post a picture (with a circle or something) of the brake booster line that you are suppose to use (on a 3100 preferabley). I feel stupid asking this.. :| Driver's side, right against the firewall. See the hose right behind the tranny dipstick? (yours should be right there too.): Quote
