NuthinFancy92GP Posted January 30, 2003 Report Posted January 30, 2003 First of all, just want to say it's good to see so many other w-body folks out there. I think I'll probably keep my GP until I can pass it on to my son! I do want to ask though, if someone can explain to me how to get to the signal light switch on a steering wheel w/ the stereo controls. I'm not sure how to get the button pad off w/o tearin' somethin' up. By the way has anyone tried the fix listed for the "fuel light" and "check gauges" light being stuck on? Thanks in Advance Orlando Quote
hambone Posted January 30, 2003 Report Posted January 30, 2003 on my '89 i had to use a thin walled socket ( i think 7mm ? ) to remove two bolts from the back of the steering wheel 'spokes'. this allowed for the removal of the pad. disconnect the wire harness from the pad and use c-clip pliers to remove c-clip. unscreww steering wheel bolt and pull steering wheel ( sometimes hard without puller ). pull turn signal handle from left side of column... and, if memory is correct voila ! don't know about fix, sorry... Quote
ismellrealbad Posted January 30, 2003 Report Posted January 30, 2003 in addition to what hambone said u need to unscrew the hazard switch and remove the plastic cover. i have plenty of pics if u want them of the wheel off Quote
NuthinFancy92GP Posted January 30, 2003 Author Report Posted January 30, 2003 Thanks for the tips! And yeah if you could show me some pics I'd really appreciate it. I could use all the help I can get. Quote
ismellrealbad Posted January 30, 2003 Report Posted January 30, 2003 here you go. First thing i recommend you do before anything is pull the horn fuse, cuz theres about 5 different way to accidentally set that off. Heres the c clip, nut, and holes for where the puller bolts go in. i dont know how the hell you people are able to take the wheel off without one. ive had mine off like 5 times and each time i needed the puller. youll need a t-25 bit if u wanna undo the horn ground wire to pull those pests out. youll want to. since your wheel has the controls on it i dont know how much differnt it will look from that but imagine not much on the right side is ur hazard switch, its just a phillips head screw, pop the little plastic piece off then slide the plastic cover around the column towards you those 6 metal contacts are part of the switch this is to just show u exactly all the stuff i used theres a lot more to replacing the switch. if u need anything else just ask. as for ur guage light im not sure whats causing that Quote
eclipse5302 Posted January 30, 2003 Report Posted January 30, 2003 Check gauges/low fuel light info in on Shawns site. Here is the link... http://www.w-body.com/service/checkgauges.html Hope that helps. Jason Quote
