Does 95 GP 3100 have a rev. limiter while in park?
I notice today that the motor won't rev over 4000 rpm when in park. does this car have a rev. limiter on it? I've been having an egr code pop up every now n then, could it have something to do with that? The ses light wasn't on while I experienced this though.
Yep...thats the park/neutral rev limiter.
What EGR code is setting? If its a performance code....its most likely dirty.
It was a code 77, digital egr #3 solenoid. I just took egr valve and the tube it connects to off today and cleaned them the best I could. I used carb cleaner and a toothbrush. What's the easyest way to clean the middle of that tube? Do you just spray cleaner in it and hope it washes everything out? Also I noticed today that I don't even have to press the brake pedal to put it in gear. Damn, if I could spend one day just enjoying my car instead of working on it I wouldn't know what to do with myself! :?
Oh, I have yet to test drive the thing to see if the light comes back on. I'll let ya know.
when I cleaned that same spot, I used the cleaner and bent a metal clothes hanger to break up the carbon in there. Worked pretty good.
Good.....but if the code does come back, you'll have to replace the valve. Worth a shot though.
^^ Deffinatly worth a shot, I mean 30 mins of your time and you can clean it for free. or you can spend the what 350 for a new EGR valve like I did and still have the code come back because the port wasnt clean. But if you clean the port, I doubt the code will come back.
Well, I used a coat hanger too but I couldn't get it but about a quarter of the way in on each side. The end of the coat hanger kept getting stuck on the ribs. Now the bad news, light came on. :evil: I'm gonna check the wires first, then replace if need be.
