brianteel Posted May 28, 2005 Report Posted May 28, 2005 FGP Germany F40 (MT2) Type: transverse front wheel drive, six-speed manual transaxle Engine range: 3.9L HVV6 (LZ9) Maximum engine torque: 245 lb-ft (333 Nm) Maximum gearbox torque: 295 lb-ft (400 Nm) Gear ratios: MT2 First: 3.77 Second: 2.04 Third: 1.32 Fourth: 0.95 Fifth: 0.76 Sixth: 0.62 Reverse: 3.54 Final drive: 3.55 Maximum validated gross vehicle weight: 3527 lb (1600 kg) Case material: aluminum Center distance: 197 mm Fluid type: Castrol BOT 0063 Transmission weight: 56 kg (123.5 lb) Fluid capacity (approximate): 3.1L / 3.27 qt (dry) Power take off: no Applications: Pontiac G6 what do you think that will do bolt up to a L67....looks like some nice high gearing at the top end.... from what is shows my engine will be perfect with that Quote
Canada Posted May 28, 2005 Report Posted May 28, 2005 Considering that L67s make way more than 245 lb-ft, I'm curious about long term durability. 2.04/3.77 = 54% 1.32/2.04 = 64% 0.95/1.32 = 72% 0.76/0.95 = 80% 0.62/0.76 = 81% The gears really tighten up past third. I don't know what kind of power you are going to be making, but I don't think you aren't going to be able to use 5th gear (let alone 6th) as it will go to 176mph with a 6k redline and 225/60/16 tires. Plus, I think first gear might be to steep.....it stops at 35 mph. Quote
brianteel Posted May 28, 2005 Author Report Posted May 28, 2005 interesting......i think it is stronger then the 282 with the spec i have found. the top end gearing will be great for cruising on the highway though..... i guess we will find out when i bolt it up...of coarse when i find one Quote
Canada Posted May 29, 2005 Report Posted May 29, 2005 Yeah......65 mph should only be 1800 rpm with 225/60/16s.....1500 for 55. Quote
brianteel Posted May 29, 2005 Author Report Posted May 29, 2005 that would be great....with the getrag at 65 the RPMs are at 3k plus Quote
Canada Posted May 30, 2005 Report Posted May 30, 2005 A Getrag 282? W or L/N? If it IS a W (slightly deeper 5th)...at 65 mph, you are at 2400 rpm with 225/60/16 tires. Quote
Canada Posted May 30, 2005 Report Posted May 30, 2005 I'm really bored......if anyone reads SCC, you'll know were I got this.... That yellow is hard to read......I'll have to switch that to gold or something. Quote
brianteel Posted May 30, 2005 Author Report Posted May 30, 2005 that looks interesting how accurate is it Quote
brianteel Posted May 31, 2005 Author Report Posted May 31, 2005 ah...well that is b ig help in deiciding if this is worth it Quote
Guest Gp crazy Posted June 3, 2005 Report Posted June 3, 2005 it would be nice if were hooked up the new 5.3 v8 engine it would go alot faster! i think Quote
brianteel Posted June 3, 2005 Author Report Posted June 3, 2005 i dont think the bell housing is the same Quote
