cramez Posted May 27, 2005 Report Posted May 27, 2005 Car is a 94 Grand Prix SE sedan, 3100/4T60-E with 139k. Niether of my cooling fans are kicking on. The primary doesn't turn on at all, and the secondary doesn't turn on even with the a/c (although niether does the compressor). The coolant temperature sensor near the thermostat housing looks to be new, but I'm not sure if that's the one for the gauge or for the ECM (there were two separate ones if I remember right). Where's the second one? BTW--The service engine light was on last week due to a vacuum leak, and the fans kicked on with the light then, so I think that rules out fan relays/fuses/most wiring connections. Any ideas? Quote
jdcutty Posted May 27, 2005 Report Posted May 27, 2005 Hard wire the fans and put a toggle switch in. turn the fans an when the car gets warm. Quote
topless94style Posted May 27, 2005 Report Posted May 27, 2005 The other sensor is either on the intake manifold or one of the heads, probably the back one if its on a head. Is your car getting hot enough? Kind of a stupid question but, my old car, while it was a 4 banger, rarely got hot enough to kick on the fans. Quote
1990lumina Posted May 28, 2005 Report Posted May 28, 2005 Does the aux. fan kick in with the a/c?? Quote
GnatGoSplat Posted May 28, 2005 Report Posted May 28, 2005 Rule out the coolant fan motors by pulling the relays and jumpering a wire across terminals that correspond to pins #30 and #87 on the relay. Quote
THe_DeTAiL3R Posted May 28, 2005 Report Posted May 28, 2005 It has to get to about 3/5th on the guage before the fan(s) kick in. My a/c doesn't work so turning it on doesn't work either.. Quote
EuroSedan93 Posted May 28, 2005 Report Posted May 28, 2005 On my car when i switched on ac and just put the ac on full the fans kicked in. Quote
