Rabbi Posted May 27, 2005 Report Posted May 27, 2005 What tool do i need to remove these guys?? Ive called EVERY automotive place within a 100 mile radious. Nobody has any idea where to buy/rent one of these. Ive even called speciaty tool shops. NOPE anyway where can i buy one of these online? Or is there anyway to remove the gears WITHOUT a camshaft gear holding tool? thanks Quote
Guest TurboSedan Posted May 27, 2005 Report Posted May 27, 2005 what engine? and....wrong section....moved.... Quote
joey b Posted May 27, 2005 Report Posted May 27, 2005 You have to have a cam hold down tool. Get some key stock and cut it, then drill it. You need to do this to remove the bolts from the cams. After that you pull the cam COGS (not pulley). Quote
Rabbi Posted May 28, 2005 Author Report Posted May 28, 2005 You have to have a cam hold down tool. Get some key stock and cut it, then drill it. You need to do this to remove the bolts from the cams. After that you pull the cam COGS (not pulley). i was under the impression that the hold down tools were only to hold the cams in place. And that you still need a cam gear puller to break the bolts to pull the lock rings. It shows the tutorial on 60 degree v6 , it says to use both tools. Quote
Rabbi Posted June 4, 2005 Author Report Posted June 4, 2005 can anyone help with my above answer? Quote
Canada Posted June 4, 2005 Report Posted June 4, 2005 I just use the cam hold down tool. Most of the time the pulleys fall off.....otherwise they just need some simple encouragement from a soft faced hammer. Quote
Rabbi Posted June 10, 2005 Author Report Posted June 10, 2005 I just use the cam hold down tool. Most of the time the pulleys fall off.....otherwise they just need some simple encouragement from a soft faced hammer. hmm what about installation? Do i not need the cam gear puller PERIOD ? Quote
