Jimz88Cutlass Posted May 25, 2005 Report Posted May 25, 2005 So I am troubleshooting some things on this car before I yank it out of the yard and the digital dash has be puzzled. When I turn the key to the on position with my Beretta, the digital dash lights up (tach, speedo, odo, etc) Is it suppose to do the same thing with the 88' CS? If so, what, besides burnt bulbs (which I have already checked) could be the culprit? Thanks, Jim Quote
Lee Posted May 25, 2005 Report Posted May 25, 2005 Dead Battery I'm sorry. Just had to say it. But you didn't say whether the car starts or not. If it runs and the dash is blank it could be several things. Loose or broken wire to the power pin-out in the connector, burnt out circuit board. There are guys here who know more about it. Quote
Jimz88Cutlass Posted May 26, 2005 Author Report Posted May 26, 2005 Does the car have to be running for the dash to illuminate? My Indy lights up with the ignition in the on poistion. Quote
94CutlassSLCoupe Posted May 26, 2005 Report Posted May 26, 2005 it will light up with the ign switch in RUN position...if you have a base cluster its probably a bad solder joint...in which case, just convert the car to UB3 Quote
