93CutlassSupreme Posted May 23, 2005 Report Posted May 23, 2005 where's the firewall hole to pass wire though? thanks Quote
slick Posted May 23, 2005 Report Posted May 23, 2005 It's to the left of the brake booster, about 6-7" down from the weatherstripping. Quote
93CutlassSupreme Posted May 23, 2005 Author Report Posted May 23, 2005 which left? pass or driver's side? Quote
slick Posted May 23, 2005 Report Posted May 23, 2005 LOL, passenger side. If ya can't find it, give me a call. Quote
cutlsp Posted May 23, 2005 Report Posted May 23, 2005 LOL, passenger side. If ya can't find it, give me a call. LOL you mean DRIVER side its to the left of the brake pedal kevin you should see a shiny little bolt thing. its a litte higher then that to the right i think.. pull the padding back to get a better look at it then stick a LONG screw drive through it. Quote
slick Posted May 23, 2005 Report Posted May 23, 2005 LOL, passenger side. If ya can't find it, give me a call. LOL you mean DRIVER side its to the left of the brake pedal kevin you should see a shiny little bolt thing. its a litte higher then that to the right i think.. pull the padding back to get a better look at it then stick a LONG screw drive through it. I think he knows what i mean when I say left of the brake booster. I think when he said passenger or drivers side, he was asking which left. Quote
cutlsp Posted May 23, 2005 Report Posted May 23, 2005 LOL, passenger side. If ya can't find it, give me a call. LOL you mean DRIVER side its to the left of the brake pedal kevin you should see a shiny little bolt thing. its a litte higher then that to the right i think.. pull the padding back to get a better look at it then stick a LONG screw drive through it. I think he knows what i mean when I say left of the brake booster. I think when he said passenger or drivers side, he was asking which left. I think i know cutlasses better then you since i own 3 of them i said how i found the empty grommet and told kevin right where to look for it. Quote
93CutlassSupreme Posted May 23, 2005 Author Report Posted May 23, 2005 thanks for the help, Chris and James. i will ask if i can't find it. Quote
cutlsp Posted May 23, 2005 Report Posted May 23, 2005 if you can't find it i'll run out there and take a picture of the damn thing so you can see it Quote
slick Posted May 23, 2005 Report Posted May 23, 2005 I think i know cutlasses better then you since i own 3 of them . Are you an idiot? They are in the same location in every w-body, cutlass or not. Quote
cutlsp Posted May 23, 2005 Report Posted May 23, 2005 I think i know cutlasses better then you since i own 3 of them . Are you an idiot? They are in the same location in every w-body, cutlass or not. LOL, passenger side. If ya can't find it, give me a call. need i remind you YOUR the one that posted this Quote
slick Posted May 23, 2005 Report Posted May 23, 2005 I think i know cutlasses better then you since i own 3 of them . Are you an idiot? They are in the same location in every w-body, cutlass or not. LOL, passenger side. If ya can't find it, give me a call. need i remind you YOUR the one that posted this Need I reming you my response to this earlier? I said its to the left of the brake booster. When he asked pass. or driver side, he obviously was asking which left, as there is only 1 brake booster. Quote
cutlsp Posted May 23, 2005 Report Posted May 23, 2005 i said where i found it and i have found it is different from 88-91 to 92+ its in a different location but since you know anything and everything about w-bodies. i guess i must be wrong but whatever its your problem Quote
cutlsp Posted May 23, 2005 Report Posted May 23, 2005 here is what you need to look for kevin. Since chris won't stop saying i'm wrong i did a write up where to look for it :verymad: Quote
GP1138 Posted May 23, 2005 Report Posted May 23, 2005 James, drop it. That picture is completely useless, and most of your contribution to this thread hasn't helped. Let it go. Quote
Psych0matt Posted May 23, 2005 Report Posted May 23, 2005 James, drop it. That picture is completely useless, and most of your contribution to this thread hasn't helped. Let it go. Quote
cutlsp Posted May 23, 2005 Report Posted May 23, 2005 whatever if you all don't think i can tell kevin where the firewall hole is thats your business of . since all i seem to do is be giving the wrong advice opposed to CHRIS who was wrong from the begining. FYI!!! i have pulled the dash out of 20+ w-bodies and now i can find that grommet with my eyes CLOSED Quote
GP1138 Posted May 23, 2005 Report Posted May 23, 2005 whatever if you all don't think i can tell kevin where the firewall hole is thats your business of . since all i seem to do is be giving the wrong advice opposed to CHRIS who was wrong from the begining. FYI!!! i have pulled the dash out of 20+ w-bodies and now i can find that grommet with my eyes CLOSED James, it's a fucking hole in the firewall. I'm sure Kevin is smart enough to find it with even Chris' description if you think what he said is so incorrect. Get over it, it seriously does not matter. If you reply with more arrogance I'll courthouse you. Quote
Brian P Posted May 23, 2005 Report Posted May 23, 2005 wholly shit take some medicine bitches!!! The way I read it, Kevin was confused on which "left" was meant, because when looking at the brake booster, the "left" is the "passenger side" direction! But technically when you're looking under the hood, things to YOUR left is considered "right" since the passenger side is the official "right" of the vehicle. It's backwards when you're facing the opposite direction the car is pointing (forwards). Slick, not to stick it where the sun dont shine but the grommet is between the booster and Drivers side strut, so James is right. Quote
cutlsp Posted May 23, 2005 Report Posted May 23, 2005 Slick, not to stick it where the sun dont shine but the grommet is between the booster and Drivers side strut, so James is right. Quote
GP1138 Posted May 23, 2005 Report Posted May 23, 2005 Slick, not to stick it where the sun dont shine but the grommet is between the booster and Drivers side strut, so James is right. Regardless, next time you are (or think you are) right about something, try to find a less insulting and more intelligent way to argue your point, rather than acting like a bratty teenager. (Hint: if your rebuttal involves the ":roll:" emoticon, it needs to be rewritten.) Quote
White93z34 Posted May 23, 2005 Report Posted May 23, 2005 heres food for thought, that hole as i recall is for 5 speed linkages, kevins may be full of his shifter linkages since his car is a stick, but i don't knwo for certin. Quote
GP1138 Posted May 23, 2005 Report Posted May 23, 2005 heres food for thought, that hole as i recall is for 5 speed linkages, kevins may be full of his shifter linkages since his car is a stick, but i don't knwo for certin. That is true, I think. Also, there is a firewall hole right in the center (almost straight back from the PCV on the back of the engine) where the auto shift cable goes on 4-speed car. I know this for certain because I had to change mine. Quote
