Jostran911 Posted May 22, 2005 Report Posted May 22, 2005 I am putting a 94 3100 into a 91 cutlass Supreme any one know how to adapt the fuel lines? The 94 has quick connects? thanks Jack Quote
twind Posted May 22, 2005 Report Posted May 22, 2005 the easiest way is to cut them and use rubber hoses to reconnect them, that is what i did. Quote
Dan94Z34 Posted May 22, 2005 Report Posted May 22, 2005 make sure you use rubber hose disigned for fuel injection. regular fuel line for like a carb car only sees around 8psi. fuel injection is in the neighborhood of 30psi. I made this mistake once and the fuel pressure blew a hole in the middle of the line, causing fuel to go everywhere. Quote
