5 speed swap parts *Update: A few more Qs..*
The bellhousing is different between the Quad/Twin cam 4 bangers and the V6s..
Master cyl is on the firewall between the strut tower and brake booster. Once you remove the arm from the clutch pedal just remove the retaining screw and twist ccw 45 degree's and it'll pull straight out. Slave cyl is bolted to the trans, but one from a Quad4 car or 3.1L cavi will work.
I just pulled the whole setup again today actually from another '90 GP :D woot!, only thing I didn't pull was the pedals... there's no way I'm going through that again. :lol:
It took way longer this way but was less painful/stressful, I had also planned on swapping the dash at the same time.
There's a bunch of pictures on my cardomain site and I had started a writeup somplace which has a complete parts list and instructions, I'll see if I can find it.
I've got a bunch of chips and basically everything needed for doing another swap so I may be able to help you with parts. Also know pretty well all the interchangeable parts cars too. Let me know if you need any more help.
I found my write-up but it's no where near done. I will finish it if it will be put on the site somewhere.? Otherwise it's not worth the effort like the last wirte-up I tried to have posted.
Baddflash, consider everything you have for a 5 speed swap sold to ME
EDIT: I love you, man :D
I love you, man :D
:fruity:
:lol:
