kadoi Posted May 21, 2005 Report Posted May 21, 2005 Hey guys been awhile since i have been here. I got my car running again and it ran great for a few weeks. It has started this thing where it will run fine for a couple days and then one day it just will up and die and not run again for another couple of days, and this happens over and over. What could cause this. Thanks. Quote
90TGP Posted May 21, 2005 Report Posted May 21, 2005 Maybe a bad fuel filter/ pump/ injecter or a bad spark plug/ plug wire/ ignition coil. Quote
TurboGTU Posted May 22, 2005 Report Posted May 22, 2005 Maybe a bad fuel filter/ pump/ injecter or a bad spark plug/ plug wire/ ignition coil What he said. Off toppic..but I don't think your 16 anymore :?: . If you are :shock: . Quote
mfewtrail Posted May 22, 2005 Report Posted May 22, 2005 Your car is fairly high mileage isn't it? I would place my bets on the fuel pump going out(my 93 SE did something very similar when the pump on it died a while back...244K on it ). Can you hear the fuel pump priming when you turn the key over(it should be audible)? Quote
