dohc v6 Posted May 20, 2005 Report Posted May 20, 2005 i have a clunking /ticking noise when ever i brake or turn it sounds like it is coming form the driver side wheel. if i am going about 20 and push on the brake kinda hard i can feel it in the pedel. so my guess is either the sway bar bushings,brake caliper sticking, pads, rotors, or something else. i need help. 94 lumina z34 Quote
jdcutty Posted May 20, 2005 Report Posted May 20, 2005 could also be a wheel bearing or a half shaft. My dads half shaft is bad on his Z and it sounds horrible. I think they are like 100 bucks or so and usually pretty simple to change out. Quote
dohc v6 Posted May 20, 2005 Author Report Posted May 20, 2005 no this does not sound like that kinda noise. it feels like something is loose or something. but it is driving me out of my mind Quote
rudefyet Posted May 20, 2005 Report Posted May 20, 2005 engine cradle and cv joints are also possible culprits Quote
dohc v6 Posted May 20, 2005 Author Report Posted May 20, 2005 i will jack it up to night. but for now it sounds like a warped rotor. i checked the wheels they are on tight enough and the brakes are pretty tight so i will look around Quote
dohc v6 Posted May 21, 2005 Author Report Posted May 21, 2005 got under there and it looks like the sway bar budhing is no longer could that cause anything. Quote
