Actual Dyno CHARTS.
Canada
you should be way higher than that for WHP.....I dyno'd bone stock and put down 125 and another local 95 GP w/ 3400 U/L intake swap put down 144ish....
something doesn't seem right....
That is true, But the HP curve is way flater in the top end vs. a near stock 3100, Looking at some of the older dyno charts i seen i have 130 HP at about 5750RPM vs. 100HP on a near stock 3100. So the peak may not be very impressive, But the curve is wayy better IMO. It does seem a little low to me also, But i am happy with the flater curve. That and i still need a downpipe. :willynilly:
Link to comment
Share on other sites
I bet w/ my manfold and 2.5" DP we would be a great race....
Yes! I agree, I would love to see that race. :high5:
Get a 2.5" DP before you tune....and you will be amazed....TRUST ME
Definetly, I seen the vid of your car after you installed the DP, And it seems about the same as my car with all my mods. I must get some exhaust work done sometime. :cool:
Link to comment
now that it's getting cool out....the GP loves it...
I was cruising at 20ish tonight and punched it, downshifted into 1st and turned them over for quite a ways....
woot for a new trans too...LOL
Link to comment
  • 2 months later...
  • 5 months later...
  • 11 months later...
My stock pull laid over my current pull. I have a custom front manifold and 2.5" DP for major mods so far.
This is computer corrected numbers for when the TQ is multiplying during accel
uncorrected
Link to comment
  • 3 weeks later...
what gear did you do that pull in?
seems like the turbo was spooling up that whole pull....the TQ never "really" levels out....just up the whole way and drops off.....
Link to comment
it drops off a 6k because i was on a smaller ar turbine housing, but the turbo is fully spooled (19psi) well before 4k rpms, so yes im in boost for most of the run..
4th gear.
look at my old dyno a few up from this, same thing, the torque just keeps climbing,
Link to comment
  • 1 year later...
Here's mine for the 01 last year. 277whp and 284wtq Mustang dyno.
Mods:Topswap, GPS #1 cam, SSIC, 3.1 pulley, HAI, Pacesetters, 3" exhaust to 2 1/4 split thrush turbo mufflers, Crap tune, built trans.
Pretty hot in the building too.
Video
[video=youtube_share;tNR9C8gRotw]
Link to comment
  • 2 years later...
I know this thread has been empty for a long time but I just got my first dyno run in since getting the car. Wanted to post results to add to the collection.
'99 GTP, 78,xxx miles, ZZP CAI, ZZP 10.3mm Wires.
220 HP / 272 TQ
Hope to start making more soon! :)
Link to comment
  • 1 month later...
Niceeee, im thinkin someday would like to see 300hp to the wheels and i'd be happy, thats also a pretty good chunk of tq too
Sent from my YP-G70 using Tapatalk 2
Link to comment
  • 6 years later...
you guys also need to realize every dyno has a different correction factor depending on the area, that can skew numbers alot,  if you make 300 on one, you might only show 278 on another, its all in the correction and thats why its good to use the same dyno for results on a new mod or tuning.
Link to comment
yes, that's true.
I'm really wanting to dyno mine in the spring.  I haven't dyno'd a car in a long time except when I had my Subaru dyno tuned.  They used a Mustang dyno, which shows less than a DynoJet
Link to comment
