spark plugs on newer gp
I'm workin on a 2000 GP with the 3100 and I wanted to know if you still have to the engine unbolt trick to get the rear bank of plugs. If at all possible i would preffer not to move the engine as it is very time consuming and i only have 2 hours to get anything each day because i'm working on it at school.
How the hell is it time consuming? It's two godamn bolts..
:werd:
You should be able to without rotating the motor forward with the 3100 considering I can change the plugs on 3800 equipped 2nd Gen's without doing so. It would however make things easier if you do rotate it forward......
