Regal_GS_1989 Posted May 26, 2005 Report Posted May 26, 2005 Weren't the 3100's that were available in 93's Multi-Port injected, rather that SFI like the newer ones?? I think I remeber seeing a picture of one where the plenum said 3100 Multi Port FI. Quote
digitaloutsider Posted May 26, 2005 Report Posted May 26, 2005 Think the '89 GP's. The 3.1 was put in mid-year. Quote
White93z34 Posted May 26, 2005 Report Posted May 26, 2005 i've heard several people debate that the 3.1 was few and far between in 89' however i've seen some with the 3.1. and for a 93' to get it i'd imaigine would have had to be REAL late production ones since the 3100 didn't officially debut till 94' Quote
TheOneAnd Posted May 26, 2005 Author Report Posted May 26, 2005 Woah, didn't expect to see a discussion break out on the motor, yes its a 3100 SFI with a round airbox, car was built in March of 1993. Anyways, ok, so got the gasket set, just a few more questions, the injectors shoud I clean them while there out or just replace them, they look kinda rusty but not badly.. any thoughts. And did anyone know exactly what the head set from GM is suppose to come with, meaning the exhaust manifold gaskets, before I go back to complain a little. THanks you all have been a big help. TOny Quote
jeremy Posted May 26, 2005 Report Posted May 26, 2005 i've heard several people debate that the 3.1 was few and far between in 89' however i've seen some with the 3.1. my '89 LE had a 3.1L........ I apologize to the poster about taking this off topic, I have just never seen a '93 with a 3100.... Quote
Brian P Posted May 27, 2005 Report Posted May 27, 2005 Did the box list the contents of the head set? Quote
Brian P Posted May 27, 2005 Report Posted May 27, 2005 Think the '89 GP's. The 3.1 was put in mid-year. But if you got a stick shift, it was only mated to a 2.8 in '89. Strangely but truly (madly.....deeply) Quote
TheOneAnd Posted May 27, 2005 Author Report Posted May 27, 2005 No list, but did find out that it didn't come with them even after being told, so they gave me the gaskets for around 25 instead of retail. So it worked out ok. Anyways does anyone know the torque specs for the headbolts, and all the other bolts and the patterns to be torqued. Let me know thanks. Quote
Brian P Posted May 27, 2005 Report Posted May 27, 2005 mm.... head bolts all to 33 lb ft THEN additional 90 degrees tighten. There is a specific pattern you have to follow, if I can find a pic I'll post it. Lower intake bolts: http://www.60degreev6.com/TSB/TSB14-3x00.html All other specs you can find here: http://www.60degreev6.com/modules.php?op=modload&name=Pushrod&file=index&req=viewarticle&artid=37&page=1 Quote
TheOneAnd Posted May 28, 2005 Author Report Posted May 28, 2005 UPDATE So I got everything put together just now, and went driving around, notice a knocking noise under the valve cover in the front, so that is easily fixed be tightening the rocker down thats loose, I knew one didn't feel right. also, the car is idling pretty rough and will shut down whilst idling.??? any ideas, I did bleed the gas lines to relieve pressure so maybe something with not enought fuel getting to the cylinders??? let me know guys thanks. Quote
joberlee Posted May 28, 2005 Report Posted May 28, 2005 http://www.w-body.com/forum/viewtopic.php?t=17912 Question 18 Quote
TheOneAnd Posted May 29, 2005 Author Report Posted May 29, 2005 That will help, also, took off the valve covers again, the front rocker bolts were slighty loose, so tighten to spec, the rears tightened to spec except for one where the stud had broken, anyone know where to get just one stud for the rocker. THanks. Tony Quote
