willsv8 Posted May 17, 2005 Report Posted May 17, 2005 when i push on the gas pedal it feels like it's not getting any gas. but in park runs smooth unpluged the tcc went for a ride that was not it. put a new iac that was not it what NOW the motor is a 2.8 with only 108.km on it and some time it's hard to start when warm need to fix this a.s.a.p because the wife is thinking that i love this car more then her because all the time i spend with it :shock: Quote
sonyman87 Posted May 18, 2005 Report Posted May 18, 2005 when you unpluged the TCC what exactly do you mean that is. the Torque converter? also dose it matter if your in motion if it cuts out or can you rev normal in idle? more details the better. does it hit a certin rpm befor it cuts out or is it random Quote
willsv8 Posted May 18, 2005 Author Report Posted May 18, 2005 yes the torque converter plug. and when in motion it cuts out. in park it rev's up fine checked the fuel pressure at 43 psi looked fine left the pressure tester on for 2 hrs went back to the car it was at 0 psi is that ok ?? Quote
Guest TurboSedan Posted May 18, 2005 Report Posted May 18, 2005 sounds normal in terms of fuel pressure. 43psi is what i get too. Quote
JS91Z34 Posted May 18, 2005 Report Posted May 18, 2005 does it pop back through the intake at all? Quote
willsv8 Posted May 21, 2005 Author Report Posted May 21, 2005 well found that was wrong with the car it was 2 bad plugwire's burnt out at the boot inside near the plug and the map sensor was gone and the cat was pluged because of the map sensor after the new M.S.D wire's now the car run's great and some new found power !!!!!!!!!!! thank's for your input on this GUY'S Quote
