willsv8 Posted May 15, 2005 Report Posted May 15, 2005 if you unplug it whats the downfall will it fuck up the tranny ? can you still go on the highway like that any drop in gas milege thanks Quote
mihela816 Posted May 15, 2005 Report Posted May 15, 2005 It can cause extra heat build-up when the TCC is not engaged. Plus you lose a few MPG's. Quote
willsv8 Posted May 15, 2005 Author Report Posted May 15, 2005 is the heat build up in the tranny or motor ? but will it harm the tranny Quote
Guest Posted May 15, 2005 Report Posted May 15, 2005 is the heat build up in the tranny or motor ? but will it harm the tranny Both, techically. The motor will be reving higher in 4th gear and the tranny will be spinning faster as well. Yes, it will harm it over time. Quote
JS91Z34 Posted May 18, 2005 Report Posted May 18, 2005 you don't want to unplug the TCC unless you have no other choice. That extra heat is bad on that tranny, or any tranny for that matter. Some tranny just take it better than others. Quote
Tru2Chevy Posted May 18, 2005 Report Posted May 18, 2005 Yea, I've had it unplugged for about 6 years on my '91 (3.1/3sp auto), put about 75k-80k miles on it since then, and the tranny still shifts fine and the fluid looks good. As long as you keep up with your maintenence, it won't be a big deal. - Justin Quote
