digitaloutsider Posted May 15, 2005 Report Posted May 15, 2005 sawzalls? we don't need no stinkin' sawzalls You will need: Drill (preferably pretty powerful) Chisel Hammer Directions: Drill 4 holes in the side of the door. Chisel them out in the form of a square. Peel sheet metal away.. it's like a hot knife through butter when you get this far. Reach in the hole with a screwdriver and find a lever attached to a spring. Pull the spring forward. Enjoy the results after nearly a year of failed attempts to get this piece of shit door open. Quote
THe_DeTAiL3R Posted May 15, 2005 Report Posted May 15, 2005 HAHAHA!!! A pick axe would probalby work fine as well.. Quote
NOHC_WBody Posted May 15, 2005 Report Posted May 15, 2005 Wouldn't it have been easier & more fun to throw a brick through the window? Quote
GutlessSupreme Posted May 15, 2005 Report Posted May 15, 2005 Wouldn't it have been easier & more fun to throw a brick through the window? Probably.. but he's not locked out door just never wanted to open, locked or unlocked. Quote
Brian P Posted May 16, 2005 Report Posted May 16, 2005 with the door panel off, still couldnt get it open?? Quote
5speedz34 Posted May 16, 2005 Report Posted May 16, 2005 Yeah, I can't believe that with the doorpanel that you couldn't get it opened. Was this on the outside and inside. Quote
digitaloutsider Posted May 16, 2005 Author Report Posted May 16, 2005 Both linkages completely failed, inside and outside. Ask Chris. There's nothing we could do short of this. Quote
White93z34 Posted May 16, 2005 Report Posted May 16, 2005 yes, i was sure i could get the fucker open, from the inside, but desperate measures were needed. Quote
5speedz34 Posted May 16, 2005 Report Posted May 16, 2005 but desperate measures were needed. Yeah, no shit. Quote
Sasquatch Posted September 27, 2010 Report Posted September 27, 2010 so i have a 92 z34 and the door wont open from inside or out. no its not locked. im sure i busted it because i was replacing the door handle and lock. when i shut the door it wouldnt open. luckily i had the door panel off when i shut the door. can some one tell me what to do without mangling the outside of the door? Quote
94 olds vert Posted September 27, 2010 Report Posted September 27, 2010 Holy old thread, Batman! Quote
Sasquatch Posted September 27, 2010 Report Posted September 27, 2010 its my first post. should i re post somewhere else? Quote
94 olds vert Posted September 27, 2010 Report Posted September 27, 2010 its my first post. should i re post somewhere else? I would. It will probably help you solve your problem faster. This thread doesn't really have any intention to open a stuck door properly without destroying your w-body. Listened to SteppenWolf- Magic carpet ride while typing this. Quote
Sasquatch Posted September 27, 2010 Report Posted September 27, 2010 Where should I post? Nice music choice. I just downloaded seven albums by him Quote
94 olds vert Posted September 27, 2010 Report Posted September 27, 2010 Where should I post? Nice music choice. I just downloaded seven albums by him I'd post it in "General". LOL thanks. I like steppenWolf. Quote
