your_I.D. Posted May 13, 2005 Report Posted May 13, 2005 Held Motor Sports is now offering 13 inch brake kits with 4 piston calipers http://www.heldmotorsports.com/mcbrakes.html Quote
White93z34 Posted May 13, 2005 Report Posted May 13, 2005 and for the $2200 for all 4 wheels i could buy 4 w-bodys! Quote
94CutlassSLCoupe Posted May 13, 2005 Report Posted May 13, 2005 I just want to be able to use the braking system off of the Gen II cars...trust me...it is sufficent. The thing that I quite honestly don't get is why my '70 Duster with 10.87" front rotors and 10x2.5" rear drums will whip a w-body in stopping distance when it wieghs within 200lbs... Its not like the brakes are huge or anything...but damn atleast that car will stop! I swear it has to do with the Master Cylinder or something... Quote
GnatGoSplat Posted May 13, 2005 Report Posted May 13, 2005 Old cars have super power assist. That's why with a lot of them, a quick tap will lock up all 4 wheels. At least, all my old cars were like that. Quote
94CutlassSLCoupe Posted May 13, 2005 Report Posted May 13, 2005 my duster has NO power assist...yet it destroys w's in the braking department Quote
GnatGoSplat Posted May 13, 2005 Report Posted May 13, 2005 Hmmm, must be the MC then. I know my old cars MC's were a lot bigger. Probably 4x bigger. Quote
z34_nut Posted May 14, 2005 Report Posted May 14, 2005 plus it most liekly has a single piston up front which allows for a great flow of brake fluid to the front caliper. Gm has used the same brakes for their truck, rwd platforms for a long time (the braking system on my 86' blazer was very similar to the brakes in my 72 nova). These brakes work awsome, but more pistons on either side of the caliper will help greatly. Also, our master cylinders don't deliver the same amount of PSI to the pistons. I dunno, theres alot more to say, but I don't feel like getting up and getting my brake books. Quote
terryk2003 Posted May 14, 2005 Report Posted May 14, 2005 i think the ABS makes stopping distance longer too...cause it seems like i can stop something old with no abs alot faster then a newer ABS car... :? Quote
GutlessSupreme Posted May 14, 2005 Report Posted May 14, 2005 \ said: i think the ABS makes stopping distance longer too...cause it seems like i can stop something old with no abs alot faster then a newer ABS car... :? I disagree. The TGP's PM3 will easliy throw me through the windshield; the Cutlass.. well, go watch the Regal police chase video in Whatever. Quote
GnatGoSplat Posted May 14, 2005 Report Posted May 14, 2005 ABS is only activated when a wheel locks up, so under normal braking, the ABS has nothing to do with the stopping distance or pedal effort. Quote
terryk2003 Posted May 14, 2005 Report Posted May 14, 2005 ok...well, you proved me wrong...so i guess it all goes back to the fact that older cars stop better because of the better booster & master cylinder... Quote
94CutlassSLCoupe Posted May 14, 2005 Report Posted May 14, 2005 \ said: \ said: i think the ABS makes stopping distance longer too...cause it seems like i can stop something old with no abs alot faster then a newer ABS car... :? I disagree. The TGP's PM3 will easliy throw me through the windshield; the Cutlass.. well, go watch the Regal police chase video in Whatever. Gotta be the Master Cylinder then...that would be the only difference I can see between a '92 cutlass supreme's brakes and a '90 TGP I wonder if there are any better MC/ABS units that can easily be swapped out...a 2nd gen unit would probably work well...or one from a bonneville if they actually made those with rear disks. Quote
