Plenum Removal / Reinstall Q
In what order do the plenum bolts have to be tightened after it has been removed? any help would be greatly appreciated. The reason I ask is because i'm replacing that pain in the ass PCV Valve tomorrow and dont want to screw something up. the engine is a 3.1 as well.
If no one gives a specific order, which im sure there is one, just go in a cris cross pattern starting on the outsides and move towards the middle.
Guest TurboSedan
start on the inside and move outwards in a 'spiral' pattern. a Haynes or Chilton will tell you. if you don't have one the local Public Library will :)
