It's smaller. I don't know exact numbers though.
Guest TurboSedan
it's a T25 with smaller A/R turbine and compressor housings i believe. Kenny might know; i think he used to own a Sunbird Turbo.
There are a couple of models of the Garrett turbos over the years of Sunbirds. 1986 and older was a 1.8L 4 cylinder with a TINY T-02! 1987 and newer was a T-25 on the 2.0L cars.
The list shows that the T-25 on the GP's was a TB2528. The Pontiac 2.0L cars used a TB2506 on the 1987 model and newer.
Do a search on the web for the full specs on each of these turbos. I would be confident in saying the T25 on the 2.0L had smaller internals to ease with spooling on the 4 cylinder car.
Here is a list of the Garrett part numbers used on Pontiac turbo cars over the years...
Make Model Year Engine Turbo Turbo Model Part Num
PONTIAC Firebird/Trans-Am 89 3.8L GAR TB0348 466748-4X
PONTIAC 80-81 4.9L GAR TB0305 465518-2X
PONTIAC McLaren / Grand Prix 89-90 3.1L GAR TB2528 465939-2X
PONTIAC Grand Am 88.5 2.0L GAR TB2521 465365-1X
PONTIAC 88 2.0L GAR TB2506 466876-1X
PONTIAC 87 2.0L GAR TB2506 466876-1X
PONTIAC Sunbird 89-90 2.0L GAR TB2522 465749-1X
PONTIAC 88.5 2.0L GAR TB2521 465365-1X
PONTIAC Sunbird Watercooled Upgrade 84-85 1.8L GAR TB0239 465853-1X
PONTIAC 84-85 1.8L GAR TB0206 466204-1X
PONTIAC 2000 Watercooled Upgrade 84-85 1.8L GAR TB0239 465853-1X
PONTIAC Firebird / Trans-Am 89 3.8L GAR TB0348 466748-4X
PONTIAC Grand Am / McClaren / 89 2.0L GAR TB2522 465749-1X
Same discussion came up on the Z24 forums, so I just copy/pasted this info.
T25 from a Sunbird .49 comp A/R .47 Turbine A/R 40 trim
T25 from a TGP .68 comp A/R .67 Turbine A/R, 50 trim
The whole post: http://www.v6z24.com/jbodyforum/viewtopic.php?t=66045
Ouch, gag :thumbsdown: that small would gag our 3.1L motor. Check on eBay what they are going for and sell it there :) .
Jeff M
Looks like a TGP T25 would be a serious bolt on upgrade for the Sunbird if you could get the thing to spool! :shock: Something I may look into for one of the summer projects I have planned... 8)
Guest TurboSedan
no, the TGP T25 uses a Garrett T25 with .80 A/R compressor and .68 A/R turbine. the A/R #s are cast right into the housings.
