91grandprixGT Posted May 12, 2005 Report Posted May 12, 2005 well, I'm havin a bit of trouble here, my odometer isnt working now, the trip works but the odo wont move a bit.... any ideas? Quote
sonyman87 Posted May 12, 2005 Report Posted May 12, 2005 new dash cluster... you cant tamper with the odomiter without activating its security shit.. atleast thats what im told Quote
Grand Moff Joseph Posted May 12, 2005 Report Posted May 12, 2005 what security stuff? When I tried to swap clusters in my 90 Lumina, I rolled the odometer on the donor cluster from 178K to 38K, and it worked fine. Quote
digitaloutsider Posted May 12, 2005 Report Posted May 12, 2005 Silver lines are supposed to show up between the numbers if you roll it backwards. Quote
cutlsp Posted May 12, 2005 Report Posted May 12, 2005 i rolled mine forward cause my car has over 220000 miles on it now Quote
GnatGoSplat Posted May 12, 2005 Report Posted May 12, 2005 The odo probably needs a new motor. You can swap with a motor from any other GP cluster. The old W-body mechanical clusters aren't all that tamper resistant. You can pop the entire odometer wheel out of the red plastic frame and then all the digits are loose and can be changed to whatever you want. Quote
no1kicker Posted May 13, 2005 Report Posted May 13, 2005 The odometer motor or odometer itself is very easy to change. You'll see what I mean if you take one apart. If you try to roll the odometer backwards (without separating the numbers) it will break. I would find a cheap cluster somewhere, maybe ebay or a junkyard. If you have a base cluster, good time to upgrade. If you use the new cluster just swap your odometer over. Quote
john99gtp Posted May 13, 2005 Report Posted May 13, 2005 how does the odo break? when i got the euro cluster, i was able to roll the mileage back, and put it back together, and tested it. Quote
no1kicker Posted May 13, 2005 Report Posted May 13, 2005 Well, when I swapped clusters I played with the other car's odometer for the hell of it. When it went backwards, something snapped and the numbers were not held in anymore. Probably a little triangle shaped tab for only moving one direction. Quote
john99gtp Posted May 13, 2005 Report Posted May 13, 2005 the one thing that pissed me off was that little plastic piece that held the tabs in place. if that wasnt lined up correctly, then it wouldnt turn, but if it was lined up, it would turn. either way, isnt it illegal to do an odo swap without letting your state/town know? Quote
dbtk2 Posted May 13, 2005 Report Posted May 13, 2005 Its perfectly legal as long as you change the numbers so they are correct. Shawn Quote
no1kicker Posted May 13, 2005 Report Posted May 13, 2005 Yeah, I put my original odometer in, so it is ok. It probably isn't legal to do yourself...and it just shows how easy it is to lie about mileage. :? Quote
1990lumina Posted May 13, 2005 Report Posted May 13, 2005 Plus some guys on here know how to roll the digital clusters forward for sure...and I'm sure someone knows how to roll them backwards as well... - Jeff L. Quote
GnatGoSplat Posted May 13, 2005 Report Posted May 13, 2005 either way, isnt it illegal to do an odo swap without letting your state/town know? Only if you get caught. :read: Quote
john99gtp Posted May 13, 2005 Report Posted May 13, 2005 either way, isnt it illegal to do an odo swap without letting your state/town know? Only if you get caught. :read: isnt everything like that Quote
Stevo Posted May 13, 2005 Report Posted May 13, 2005 The old W-body mechanical clusters aren't all that tamper resistant. You can pop the entire odometer wheel out of the red plastic frame and then all the digits are loose and can be changed to whatever you want. Thats rather disconcerting Quote
dsgrntld187 Posted May 22, 2005 Report Posted May 22, 2005 Actually, from what I was reading, if you put in a new cluster, you must reset the mileage to 0 and put a sticker on the door saying what the mileage was at the time of the swap Quote
91grandprixGT Posted May 22, 2005 Author Report Posted May 22, 2005 eh whos gonna know eh? I could always reset the mileage and say it had 70k miles on it cause my insurance company doesnt ask mileage or anything I could screw someone bad, but I'm not that kind of an asshole, I'm keeping track of mileage everytime I rold the trip I mark down 1k miles on a piece of paper (Call me stupid if you want) and when I get a new cluster I will just set it at the correct mileage. just got a JVC headunit screw the steering wheel controls, gonna get windows tinted when I go to chicago and then get back put some subs, amp into the car and bump that biotch Quote
