How many bolts hold a cutlass supreme front fender on? I want to make sure I get them all when I take my fender off to do body work on it.. Thanks!
I don't know the exact number... But if you open the hood, and look along the hoodline, you have to yank those. Your hinge for the hood is welded on the fender, so you have to undo the hinge bolts as well.
Then , there are two you can see if you open the door, and look past the door jam switch.
Then two more where you take out the corner marker light.
Then two more mounted from underneath near the front of the fender, that get bolted up either near the ECM (pass side) or near the battery (drivers side).
Then 2 more just aft of the tire, on the lowest part on the car.
So NOT including the ones on the hoodline, you have 8.
