z34_nut Posted May 10, 2005 Report Posted May 10, 2005 Ok, Need your help. Seeing I don't know it off the top of my head like many people, I have to ask (and the search function BLOWS btw). I need information on coil packs. First what coil controls what cylinders, and info on what cylinder is what for example: [piston # back 1 3 5 2 4 6 front coil 1: pistons 1+3 coil 2: pistons 2+4 coil 3: pistons 5+6 Location: (in order from passengers side) coil 1, coil 2, coil 3] With my luck, thats prolly right, but I just need some facts. Quote
jeremy Posted May 10, 2005 Report Posted May 10, 2005 Firing Order: 1-2-3-4-5-6 Coil Connection Sequence: 1-4-6-3-2-5 I found this in a thread that I found using the search feature I am glad you brought this up again, because I don't know if it is correct or not, but that was the answer someone gave when this question was asked earlier. I hope someone can come in this thread and verify if that order is correct because verification never happened in the other thread Quote
z34_nut Posted May 10, 2005 Author Report Posted May 10, 2005 I found this in a thread that I found using the search feature crap! Firing Order: 1-2-3-4-5-6 Coil Connection Sequence: 1-4-6-3-2-5 so I wounder is it (f stands for front, b stands for back) 1b, 2f, 3b, 4f, 5b, 6f? if that were true, and that coil location is also true, then my first coil pack is toast (1-4) Its not firing on 1 (?) or 4(?) Quote
jeremy Posted May 10, 2005 Report Posted May 10, 2005 hopefully Slick will chime in soon, he has to know the correct info because he relocated his coil packs Quote
z34_nut Posted May 10, 2005 Author Report Posted May 10, 2005 hopefully Slick will chime in soon, he has to know the correct info because he relocated his coil packs he just went to work... :? Quote
5speedz34 Posted May 11, 2005 Report Posted May 11, 2005 Ok, I have 4 Service Manuals. Chiltons, Haynes, and the 2 GM ones. I found this in Haynes *sigh* THIS COVERS ALL W-BODY ENGINES http://img.photobucket.com/albums/v291/5speedz34/img016.jpg The pic is huge so I linked it. Quote
slick Posted May 11, 2005 Report Posted May 11, 2005 For the wires, undo the wire loom, and pull out the needed wires(the ones that connect to the plugs that go into the ICM) until you have the desired length. Then, just re-wrap up the rest of the wires, and your done. It's kind of a pain in the ass with those wires running in about 4-5 different looms, so be prepared to get dirty, and it does take a few hours. Quote
z34_nut Posted May 11, 2005 Author Report Posted May 11, 2005 and it does take a few hours. I got a whole weekend. and thanks again guys. Quote
5speedz34 Posted May 11, 2005 Report Posted May 11, 2005 Chris, post pics of where you relocated your coils to please. Quote
z34_nut Posted May 11, 2005 Author Report Posted May 11, 2005 Chris, post pics of where you relocated your coils to please. and wtf happened to studing? Quote
GP1138 Posted May 11, 2005 Report Posted May 11, 2005 and wtf happened to studing? Ask Chris that, not Tony. :lol: Quote
5speedz34 Posted May 12, 2005 Report Posted May 12, 2005 great info Tony....thanks for posting itYeah, no problem Quote
sonyman87 Posted May 12, 2005 Report Posted May 12, 2005 Shit i want to do that. do they just unbolt and you can move them or do you have to fabricate a wireing harness to connect it to its old locatoin? is there a writeup on this? btw i totaly hate where mine are at now below the exaust manifold. Quote
cutlsp Posted May 12, 2005 Report Posted May 12, 2005 Ok, I have 4 Service Manuals. Chiltons, Haynes, and the 2 GM ones. I found this in Haynes *sigh* THIS COVERS ALL W-BODY ENGINES http://img.photobucket.com/albums/v291/5speedz34/img016.jpg The pic is huge so I linked it. nice scanner tony what is it? Quote
slick Posted May 12, 2005 Report Posted May 12, 2005 Shit i want to do that. do they just unbolt and you can move them or do you have to fabricate a wireing harness to connect it to its old locatoin? is there a writeup on this? btw i totaly hate where mine are at now below the exaust manifold. Nope, no write up. I just undid the wire loom, pulled out the necessary lengths of wires, wire loomed back up the rest of it, mounted the coil pack/icm assembly where I wanted it, and that was that. Quote
