Sleek 93 SE Posted May 10, 2005 Report Posted May 10, 2005 Like the title says, everytime i shift into reverse my car shakes and makes a squeak noise. Even before the squeak the car would shift hard from park to drive or reverse, it like shook the car, is that bad? Now I got this squeak, i can not tell where its coming from but the car runs perfectly fine otherwise and it only does this into reverse. -Nick Quote
DiscoStudd Posted May 10, 2005 Report Posted May 10, 2005 Could be a loose, broken, or rusted exhaust hanger... Quote
Baddflash Posted May 10, 2005 Report Posted May 10, 2005 I would guess where the manifold meets the downpipe. Quote
1990lumina Posted May 10, 2005 Report Posted May 10, 2005 My car lurches into reverse - as well as drive...nothing sqeaks yet...but you are not alone in the sense my car shifts harsely into forward or reverse gears from park. ALmost like someone as hit your car..that is the feeling you get right?? (like small bump) - Jeff L. Quote
EurosportZ34 Posted May 10, 2005 Report Posted May 10, 2005 my Z34 used to do that every so often Quote
Sleek 93 SE Posted May 10, 2005 Author Report Posted May 10, 2005 Yep, it feels like a little nudge, even with the brake fully pressed. Quote
jdcutty Posted May 10, 2005 Report Posted May 10, 2005 Check all your motor mounts. Open the hood and have someone put the car into gear and see if the motor moves alot. The dogbone mounts aren't hard to change but there is a hydraulic mount on the bottom that is a bitch. Quote
