I have 90 regal. I put a 3100 out of a 95 lumina. it ran fine for a week or so then started idial high even low. now it will not start, but fires. i've changed the coil packs, cps, ecm, fuel pump, filter. it get fuel, but will not start. you can here the injectors come on then when the injectors shut off you can hear knocking. any ideas
the only thing that was changed was the injectors from the regal. everthing else adabted. the ecm from the regal. the engine from the lumina and everything that was on the engine was used.
it will run for about a day, then it will die start then finaaly not run at all,but will turn over.
So....right now.....it won't start no matter the day of the week?
Check compression and spark (get a spark tester...don't just hold a plug against the block)......also...check over your work. Make sure you got the correct wires to the right cylinders.
I should also ask....this car doesn't have an aftermarket security alarm...does it?
What was the psi?
What was your fuel pressure?
Correct spark.....on all cylinders?
if the fuel pressure, and compression is good what else could cause this a shorted injector? but would it still fire?
Is there a wat to bypass the crank sensor. I have no spark right now. I just want to know if the sensor before i have to spend any $$$$
Not really, but i did want to spend it if i did not have to, i did still no go.
I repalced the harness that connects to injectors, alt, map, iac, temp. The car fired before i changed this harness. now it will not even fire. the old harness had exposed wires and broken ones also. the harness came off a olds with 3.1. it was a little differnt like one alt wire instead two that were on the alt. the CPS wire was not in there, i had to pull it out. the pin outs are a little different like 4 or the color code is complely different. is there any thing else that controls the spark. i have changed ecm the coils, ignition module,fuel pump. you can here the injectors come on. i don't know what else to check
