well i took my car out for ride on the high way and doing about 60 and turning lanes it feels like the car has massive amounts of body roll. i have to put my stb front bar on should i buy the rear stb. and also if my car is not aligned would this do anything
make sure your rear sway bar is actually attached (dohc cars should have one)...Otherwise I'd say your struts (particularly rear ones) are shot
i just put the addco revised bar in and i have brand new struts all around
:shock: sounds like i'm keeping the old addco one then i don't want rear end sway :shock:
the rear is very tight it was the front the swayed. i just mispoke. the new sway bar is much better and it does not hit. it was the front i for got to hook up the braces that attach the strut tower to frame. and i have a alignment problem real bad.
well my alignment isn't screwed up i just don't have the 34mm front sway bar yet
If your alignment is out it might feel unstable at high speeds because you constantly have to make correction turns and whatnot..
- Jeff L.
