MoTox8410 Posted May 7, 2005 Report Posted May 7, 2005 i have a 93 3.4 DoHC and im getting a code for the EGR but i took it off and cleaned it in november :? so i was wondering if ya think it could be dirty again or could it of gone bad......what causes them to "clog" and what causes them to go bad at school we have a genisis pathfinder scan tool and i was wondering if you can tell the computer to test/open and close the 3 solenoids?? also ive been getting like 17 MPG and its killing me, can a bad EGR effect gas milage.... Quote
19Cutlass94 Posted May 7, 2005 Report Posted May 7, 2005 have you cleaned just the EGR itself or have you also cleaned the port from the back of the throttlebody to the EGR valve, gettin all the carbon out, because once you clean that port, it wont clog up again for several years of driving but if all of that is clean, its probably your EGR itself Quote
MoTox8410 Posted May 7, 2005 Author Report Posted May 7, 2005 umm actully i just cleaned EGR specifically the 3 ball point things :oops: Quote
5speedz34 Posted May 7, 2005 Report Posted May 7, 2005 There is a tube that it connects to that runs to the exhaust downpipe, spray carb cleaner down that. Honestly, I would just try to get a new EGR. Quote
skiiirt Posted May 8, 2005 Report Posted May 8, 2005 There is a tube that it connects to that runs to the exhaust downpipe, spray carb cleaner down that. Honestly, I would just try to get a new EGR. A new egr valve will still fail if there is a piece of carbon thats causing it to stick. I have replaced my old EGR valve and things havent improved. There seems to be one piece of carbon that I can never get Quote
Redwingvksm Posted May 9, 2005 Report Posted May 9, 2005 Get a coat hanger, cut it, and use that to clean out that tubes w/ the Carb Clean. If you just put a new EGR on it - it'll still have the exact same problem. Take the 1/2 hour it'll require and do it right. And don't complain about 17mpg!! That's almost godlike to my ears!! Quote
