Car Eating Gas...Help
My 1990 International is hard to start cold and killing gas. I can't get my plugs in all the way, it seems like the threads are off. I couldn't even get the old on back in. I need to know what is the fix...I don;t have mucj money so it goes like this.
Hard to start when cold, if I try to drive off cold, cuts off...only when cold
Bad gas mileage...especially in the city
Hesitates a bit
Rough Idle
Loss of Power
What should I do:
Fuel Filter??? which one is best
Air filter is clean
Plugs...read above
Service Engine light On....which sensor do you think
I changed oil but it keeps telling me to change oil...5 qts of 5W-30
I am out of suggestions...I know it's omething small but gas isn't cheap in DC!!!!!!! HEEELP
for the hard start I would replace the fuel pressure regulator if your fuel pump is still good, I'd get those plugs fixed as thats probibly whats causing you all your grief
for the gas mileage clean your egr valve
The oil issue is simple -- just go into the 'oil' page of the DIS, and hold down reset for a minute. The oil reminder will go away.
Fix the plugs definitely. Look at the homepage of this site and follow the instructions to pull whatever codes the ECM is showing. Those might give you a few more hints.
How is the O2 sensor? If it's old it will def. cause a rough idle and poor milage. May not throw a code unless its completely dead.
- Justin
check for vacuum leaks. it'll drive like hell if there is a leak.
What should I do:
They're pretty much all the same. I use Purolator (since that's all I can find)
Plugs...read above
Try some good ol' AC Delco's. Stay away from Bosch
Pull the codes with the instructions in the W-body FAQ's. It's really easy.
You need to change the O2 sensor. I had the same problem in my Z and within 2 bolcks of the test drive,the problems were gone. It should cost about 20 bucks for the O2 sensor. I dont know about gas milage, though.
do the fuel filter first...you probably need one anyway!
My W gets about 21 city and 30 or more on the Highway...which is pretty damn good for a v6 car of any kind!
yea, my TGP gets 24-27 city and 29-35 Highway, so there not gas guzllers
My weenie 2.8 gets around 15, maby 17 highway!!! I think they're gas guzzlers, or somthing is wrong with my 2.8....
i think you need to address your problem of the spark plugs not going in all the way. you gotta be looseing compression that way. get some good ACD plugs and get them in all the way without striping your heads.
2.8's are hard on gas
i find that hard to belive, cause many 3.1 owners including myself have gotten great gas milege in the 30's, and the 2.8 is even smaller, pretty much the same motor
I'd say i'm up around 32 MPG for highway (65/70 MPH)
But the city drops to around 15 (Very heavy foot, lots of stop-n-go)
I love my gas mileage in my 3.1...
something is wrong with your guy's 2.8s i get 33.5 mpg highway most of the time.
in the city its not as good because i have to give it quite a bit of gas to get moving and keep from getting rear ended by trucks. :?
LOL!! gotta floor it to get going, i get 33-37 mpg in my TGP on highway, woooo hhoo!! and city is in the 20-27 range usually, we dont havea huge city, so its not constant stoping and going
i admit in the city my car gets the same mile per gallons as my truck gets as highway miles.
My mom's car and my Lumina w/ 3.1 get the best mileage on the highway - however her car is way better in the city then mine could dream of..
Here's a quick run odwn of what all my families cars' get (I dunno if this a fuel economy thread...but it seems to have turned into one)
Listed from best to worst in regards to highway
1999 Acura 3.0 CL - 34 highway, 23 city
1990 Chevrolet Lumina 3.1 - 31 highway, 17 city(heavy foot to get the land yacht moving)
1996 Chevrolet Suburban 6.5TD - 25 highway, 19-20 city
1995 Ford Taurus 3.0 - 24 highway, 16-17 city
1985 Mazda RX-7 2 rotor rotary engine 1.1L w/ 4barrel carb (12a) 19 highway, 14-15 city:D lol...gotta love shittest mileage of them all, plus the added cost of maintaince of the rotary lol
- Jeff L.
my 3.1 never got good milage either
Hey! Good to see you again!
What's new, John? 8)
Just dont shove the plugs in there like the previous owner of my late Beretta did. I was driving it to college one day and the plug in the back cylindar head flew out. The threads were fucked, so I had to pull the rear head off, and get a different one from a junk yard and slap it on.
That happened to my old 2.8 in the GP I used to have. I helicoiled it, twice (again after my rush job, which lasted ~5months :shock: ) and it didn't give me problems.
I remember reading about that when it happened :lol:
