georgost Posted May 7, 2005 Report Posted May 7, 2005 Hey guys, my car started doing something funny. When I start the car, there is an audible hissing sund coming from the passenger side under the dash. I haven't taken anything apart to see what's up, but it is very strange. Sounds like an air leak. Any ideas? The heat and aircon still work fine. Quote
terryk2003 Posted May 7, 2005 Report Posted May 7, 2005 sounds like one of the vacumm lines for the heater controls...what kinda car do you have?...what year!?... Quote
georgost Posted May 7, 2005 Author Report Posted May 7, 2005 Sorry, I have a 1993 cutalss SL w/ 3.4L Quote
Prospeeder Posted May 8, 2005 Report Posted May 8, 2005 does the cruise work? do the vents change? Quote
MoTox8410 Posted May 8, 2005 Report Posted May 8, 2005 does is soumd like whining noise??it could be the fan for the heat and air Quote
georgost Posted May 9, 2005 Author Report Posted May 9, 2005 Haven't checked the cruise, will check that tonight. It isn't the fan, that makes it's own noise, but this is definitely an air leak sort of noise. I think it may have to do with the vents. Quote
buckethead Posted May 9, 2005 Report Posted May 9, 2005 my chrysler had that problem... it pissed me off big time. Good luck finding it Quote
georgost Posted May 9, 2005 Author Report Posted May 9, 2005 i tried checking the air flow: Defrost/defog worked So did the vent (upper) Don't believe the passenger footwell was working. Quote
buckethead Posted May 9, 2005 Report Posted May 9, 2005 an airleak won't necessarily mean that you'll lose your hvac controls... the controls in my chrysler worked great. The hissing noise did go away at some settings though. Is your hissing changing when you change your vents? Quote
georgost Posted May 9, 2005 Author Report Posted May 9, 2005 no it doesn't change. It is on consistently! Quote
