5speedz34 Posted May 5, 2005 Report Posted May 5, 2005 http://motors.search.ebay.com/Mobil-1-oil-cap_W0QQsofocusZbsQQsbrftogZ1QQsaspiZ2QQsamcmZ6001QQfromZR10QQcatrefZC6QQsacatZ6000QQcatrefZC6QQsargnZ-1QQsaslcZ2QQftrtZ1QQftrvZ1QQfsopZ11QQfsooZ1 Those are all on ebay anyone know if they'll fit the 3.4's? I can post pics of a stock 3.4 one if I need to. Thanks Quote
Prospeeder Posted May 5, 2005 Report Posted May 5, 2005 prolly not, its for the LS1, not the LQ1, might be a different size, just go to a j/y and get one, or to a dealer if urs is missing Quote
5speedz34 Posted May 6, 2005 Author Report Posted May 6, 2005 prolly not, its for the LS1, not the LQ1, might be a different size, just go to a j/y and get one, or to a dealer if urs is missingUhh no shit huh? Mine isn't missing I want to update it with one like that. That says Mobil 1 only. Quote
ToroToro Posted May 6, 2005 Report Posted May 6, 2005 The LS1 oil cap will fit fine. A 3.4 I seen at the yard uses the same 1/4 turn cap as every other GM car I've seen. Pretty much count on GM to share shit like that. I am using one from a 98 Z28 on my 3100. Quote
Bossman429 Posted May 6, 2005 Report Posted May 6, 2005 94+ 3400's use the 1/4 turn cap, so they can use the LS1 cap. The 3.4 DOHC LQ1 uses a threaded cap IIRC, so the 1/4 tuen LS1 cap won't work. Quote
5speedz34 Posted May 6, 2005 Author Report Posted May 6, 2005 Yeah, the caps threaded, that's what I figured. Damnit Quote
Brian P Posted May 6, 2005 Report Posted May 6, 2005 I've got the 1/4 turn mobil1 cap on my engine, but I have seen them in threaded versions they're just incredibly hard to find. Quote
Canada Posted May 6, 2005 Report Posted May 6, 2005 That cap is only $8.58 list from GM....a dealer should be slightly cheaper. $4.28 plus S&H from GM Parts Direct. Quote
