veritasz34 Posted May 5, 2005 Report Posted May 5, 2005 Well I finall got my hose clamp pliers in and got the plenum off (Thanks to those who helped). My question is??Is there anything I need to do while this thing is off getting polished..Any cleaning(Inside of plenum)??And if so what do I need to do/use..Any input will be greatly appreciated.. I'll snap some pics and post when the polishing is done..Again thanks.. Quote
Prospeeder Posted May 5, 2005 Report Posted May 5, 2005 im not aware u need to anything, check all ur vacuum lines under there, and change ur PCV valve too! Quote
5speedz34 Posted May 5, 2005 Report Posted May 5, 2005 You could spray some carb cleaner into and clean it that way. You could also get some Chem-Dip (avalable at most parts stores) and pour it into the intake. Quote
Prospeeder Posted May 5, 2005 Report Posted May 5, 2005 pour chem dip into the intake???? isnt that kinda risky? Quote
GP1138 Posted May 6, 2005 Report Posted May 6, 2005 pour chem dip into the intake???? isnt that kinda risky? I think he means the plenum. Quote
veritasz34 Posted May 6, 2005 Author Report Posted May 6, 2005 Yes I'm talking about the upper intake plenum. I have it off doing some mods..I was just wondering if their is anything to do while I had it off.. Quote
slick Posted May 6, 2005 Report Posted May 6, 2005 Port and Polish, and chem dip are the only two things that come to mind for mods while its off. Quote
WhiteOut Posted May 6, 2005 Report Posted May 6, 2005 The best thing I've found for cleaning the upper intake is gasoline. Pour a quart or so into the upper intake, swish it around a bit and pour it off into another container. Repeat a couple times, then add the washings to a some other gas and use in in your lawn mower. Works great, its cheap, and you'll get an assload of gunk out of there. I'm sure I'll catch flak for this, but I'd much rather change a single fouled plug on a cheap ass mower than plugs on my Cutlass. Quote
gp90se Posted May 7, 2005 Report Posted May 7, 2005 Gas never worked so well for me and carbon buildup. Valvoline makes a killer top end cleaner that breaks down carbon on contact, but its hard to find. Couple cans of brake cleaner or berrymans chem dip will do the job as well. Quote
White93z34 Posted May 7, 2005 Report Posted May 7, 2005 may as well do lower intake gaskets while your down that far. cheep and easy. Quote
5speedz34 Posted May 7, 2005 Report Posted May 7, 2005 You should just try to get the 96+ Intakes instead of porting and polishing. Quote
5speedz34 Posted May 7, 2005 Report Posted May 7, 2005 Gas never worked so well for me and carbon buildup. Valvoline makes a killer top end cleaner that breaks down carbon on contact, but its hard to find. Couple cans of brake cleaner or berrymans chem dip will do the job as well. Is this it? http://www.valvoline.com/pages/products/product_detail.asp?product=52 Quote
gp90se Posted May 8, 2005 Report Posted May 8, 2005 they make a 3 part kit that has a small bottle of that, a Fuel injector cleaner and a bottle of intake cleaner which is a stonger version of the spray, but yea that shit works the balls. Quote
5speedz34 Posted May 8, 2005 Report Posted May 8, 2005 they make a 3 part kit that has a small bottle of that, a Fuel injector cleaner and a bottle of intake cleaner which is a stonger version of the spray, but yea that shit works the balls.Damn, it must be hard to find. They don't list it on their site! Quote
gp90se Posted May 8, 2005 Report Posted May 8, 2005 I worked for em for a bit, might not make it anymore. Quote
sonyman87 Posted May 8, 2005 Report Posted May 8, 2005 pull the lower intake while you have it tore down that far and check to see if you are leaking oil around the valley plate Quote
Redwingvksm Posted May 8, 2005 Report Posted May 8, 2005 pull the lower intake while you have it tore down that far and check to see if you are leaking oil around the valley plate X2, since ya got 1/2 of it off - might as well play it safe. Quote
