Guest Anonymous Posted May 4, 2005 Report Posted May 4, 2005 I've already done the searches, so dont suggest that. What should be the normal oil PSi on the 3.4 when you first start it up? Quote
skiiirt Posted May 4, 2005 Report Posted May 4, 2005 Mine is usually in the middle of the guage and then quickly moves to the right tick. Sorry I don't know the numbers Quote
JJ77 Posted May 4, 2005 Report Posted May 4, 2005 40 psi then it goes up to 60 for the first 5-7 mins of driving Quote
Guest Anonymous Posted May 4, 2005 Report Posted May 4, 2005 I'm thinking maybe my sensor is bad. On the old engine, it was always about 70 psi, but I never drove it, it was always in park. On the new engine, its the same, but again, i have only driven the car 3 miles... and I know that I'm not having oil problems with this one... It just seems high to me, but again, the car hasn't been a"driven" far since last june. Quote
GP1138 Posted May 4, 2005 Report Posted May 4, 2005 On any car I've driven, Oil PSI is always high at startup, partially because the car's idle is higher to promote warming up. It sounds fairly normal to me. Quote
Whiskey River Posted May 4, 2005 Report Posted May 4, 2005 My startup oil pressure hovers around 70 psi, after 15 minutes of mixed driving and idling, it'll fall to about 40 at idle and hot idle is around 20. At temp, the oil pressure gauge reads about 60 psi at anything above idle. Quote
digitaloutsider Posted May 4, 2005 Report Posted May 4, 2005 That, and don't even bother with the pressure gauge on the Grand Prix's. Totally worthless. Quote
Guest Anonymous Posted May 4, 2005 Report Posted May 4, 2005 True, but knowing how fanatical I am with this car, everything slightly amiss worries me! Quote
SmokesGTP Posted May 5, 2005 Report Posted May 5, 2005 That, and don't even bother with the pressure gauge on the Grand Prix's. Totally worthless. Yeah the one of the Bonne is money though. My dad had an identical car to yours except dark green. I was always pissed my GP didn't have full gages. Quote
5speedz34 Posted May 5, 2005 Report Posted May 5, 2005 My Z34 when it was first started it was always way into the 80 PSI range. Once it's warmed up it should be between 20-40 PSI at idle. Quote
